Support Questions
How to avoid time out waiting for client connection with hive on spark
Expert Contributor
I have my Hive jobs scheduled through oozie and I randomly get:
ERROR : Failed to execute spark task, with exception 'org.apache.hadoop.hive.ql.metadata.HiveException(Failed to create spark client.)'
org.apache.hadoop.hive.ql.metadata.HiveException: Failed to create spark client.
	at org.apache.hadoop.hive.ql.exec.spark.session.SparkSessionImpl.open(SparkSessionImpl.java:64)
	at org.apache.hadoop.hive.ql.exec.spark.session.SparkSessionManagerImpl.getSession(SparkSessionManagerImpl.java:114)
	at org.apache.hadoop.hive.ql.exec.spark.SparkUtilities.getSparkSession(SparkUtilities.java:111)
	at org.apache.hadoop.hive.ql.exec.spark.SparkTask.execute(SparkTask.java:99)
	at org.apache.hadoop.hive.ql.exec.Task.executeTask(Task.java:214)
	at org.apache.hadoop.hive.ql.exec.TaskRunner.runSequential(TaskRunner.java:100)
	at org.apache.hadoop.hive.ql.Driver.launchTask(Driver.java:1977)
	at org.apache.hadoop.hive.ql.Driver.execute(Driver.java:1690)
	at org.apache.hadoop.hive.ql.Driver.runInternal(Driver.java:1422)
	at org.apache.hadoop.hive.ql.Driver.run(Driver.java:1206)
	at org.apache.hadoop.hive.ql.Driver.run(Driver.java:1201)
	at org.apache.hive.service.cli.operation.SQLOperation.runQuery(SQLOperation.java:237)
	at org.apache.hive.service.cli.operation.SQLOperation.access$300(SQLOperation.java:88)
	at org.apache.hive.service.cli.operation.SQLOperation$3$1.run(SQLOperation.java:293)
	at javax.security.auth.Subject.doAs(Subject.java:415)
	at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1920)
	at org.apache.hive.service.cli.operation.SQLOperation$3.run(SQLOperation.java:306)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
	at java.util.concurrent.FutureTask.run(FutureTask.java:262)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
Caused by: java.lang.RuntimeException: java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Timed out waiting for client connection.
	at com.google.common.base.Throwables.propagate(Throwables.java:156)
	at org.apache.hive.spark.client.SparkClientImpl.<init>(SparkClientImpl.java:124)
	at org.apache.hive.spark.client.SparkClientFactory.createClient(SparkClientFactory.java:80)
	at org.apache.hadoop.hive.ql.exec.spark.RemoteHiveSparkClient.createRemoteClient(RemoteHiveSparkClient.java:100)
	at org.apache.hadoop.hive.ql.exec.spark.RemoteHiveSparkClient.<init>(RemoteHiveSparkClient.java:96)
	at org.apache.hadoop.hive.ql.exec.spark.HiveSparkClientFactory.createHiveSparkClient(HiveSparkClientFactory.java:68)
	at org.apache.hadoop.hive.ql.exec.spark.session.SparkSessionImpl.open(SparkSessionImpl.java:62)
	... 22 more
Caused by: java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Timed out waiting for client connection.
	at io.netty.util.concurrent.AbstractFuture.get(AbstractFuture.java:37)
	at org.apache.hive.spark.client.SparkClientImpl.<init>(SparkClientImpl.java:108)
	... 27 more
Caused by: java.util.concurrent.TimeoutException: Timed out waiting for client connection.
	at org.apache.hive.spark.client.rpc.RpcServer$2.run(RpcServer.java:141)
	at io.netty.util.concurrent.PromiseTask$RunnableAdapter.call(PromiseTask.java:38)
	at io.netty.util.concurrent.ScheduledFutureTask.run(ScheduledFutureTask.java:120)
	at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:357)
	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:357)
	at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:111)
	... 1 more
	... 22 more
	... 27 more
	... 1 more
ERROR : FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.spark.SparkTask
INFO  : Completed executing command(queryId=hive_20180506233232_2a9bc92f-d830-435b-91df-eafd2236a9fc); Time taken: 90.051 seconds
Error: Error while processing statement: FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.spark.SparkTask (state=08S01,code=1)
Closing: 0: jdbc:hive2://ip-172-31-4-192.ap-south-1.compute.internal:10000/default
Intercepting System.exit(2)
Failing Oozie Launcher, Main class [org.apache.oozie.action.hadoop.Hive2Main], exit code [2]
What can I do to fix this? It happens randomly even at times when workload is not much
Cluster Confi:
Total vCores: 60
Total memory: 205 GB
3 worker nodes in my cluster are m4.4x Large ec2 instances, 2 m4.2x large ec2 instance with Yarn (Node manager)
Container memory is set to 8GB in Yarn config
spark.executor.cores=1(since I will have multiple users running queries and also multiple queries running at same time)
spark java heap size = 5GB
Memory overhead = 2GB
Is there something I can do to improve the situation?
5 REPLIES 5
Master Collaborator
Hi @sim6
It looks like the rpc times out waiting for resource getting available on spark side. Given that it is random indicates that this error might be happening when the cluster does not have enough resource and nothing permanently wrong with the cluster as such.
For testing you can explore the following timeout values and see if that helps:
hive.spark.client.connect.timeout=30000ms  (default 1000ms)
hive.spark.client.server.connect.timeout=300000ms (default  90000ms)
You'd need to set it up in the Hive Safety Value using the steps below, so that it takes effect for all the spark queries:
Go to Cloudera Manager home page
click through "Hive" service
click "Configuration"
search for "Hive Service Advanced Configuration Snippet (Safety Valve) for hive-site.xml"
enter the following in the XML text field:
<property>
<name>hive.spark.client.connect.timeout</name>
<value>30000ms</value>
</property>
<property>
<name>hive.spark.client.server.connect.timeout</name>
<value>300000ms</value>
</property
Restart Hive services to allow changes to take effect then run the query again to test.
Let us know how it goes.
Expert Contributor
Hello,
Thank you for your response.
 I have set the timeout to the recommended value as directed in the response. However, I still get
ERROR : Failed to monitor Job[ 8] with exception 'org.apache.hadoop.hive.ql.metadata.HiveException(java.util.concurrent.TimeoutException)'
org.apache.hadoop.hive.ql.metadata.HiveException: java.util.concurrent.TimeoutException
	at org.apache.hadoop.hive.ql.exec.spark.status.impl.RemoteSparkJobStatus.getSparkJobInfo(RemoteSparkJobStatus.java:153)
	at org.apache.hadoop.hive.ql.exec.spark.status.impl.RemoteSparkJobStatus.getState(RemoteSparkJobStatus.java:82)
	at org.apache.hadoop.hive.ql.exec.spark.status.RemoteSparkJobMonitor.startMonitor(RemoteSparkJobMonitor.java:80)
	at org.apache.hadoop.hive.ql.exec.spark.status.impl.RemoteSparkJobRef.monitorJob(RemoteSparkJobRef.java:60)
	at org.apache.hadoop.hive.ql.exec.spark.SparkTask.execute(SparkTask.java:109)
	at io.netty.util.concurrent.AbstractFuture.get(AbstractFuture.java:49)
	at org.apache.hadoop.hive.ql.exec.spark.status.impl.RemoteSparkJobStatus.getSparkJobInfo(RemoteSparkJobStatus.java:150)
	... 23 more
	... 23 more
INFO  : Completed executing command(queryId=hive_20180518120808_12c3175f-865c-47d4-9748-29853259b4aa); Time taken: 120.892 seconds
did you resolve this?
I'm am  seeing simliar issues with timeouts as jobs stack on in queue on yarn and dont get a handle/session (unassigned).  Clients disconnect and error out.  im tickering with timeout settings which seem to address longer processes having to wait.. but if a job is  still in queue (cluster is busy) perhaps the client isn't handling correctly?
  File "/home/testenv/test/phoenix/cleanse/cleanseDetection.py", line 286, in process_cd_rule
    self.execute_hive_query(query, cgid, cd_id)
  File "/home/testenv/test/phoenix/cleanse/cleanseDetection.py", line 723, in execute_hive_query
    self.hive_session.execute(sql)
  File "/home/testenv/test/msense/scripts/hive/hiveClasses/HiveDB.py", line 92, in execute
    self.__cursor.execute(statement)
  File "/usr/lib/python2.7/site-packages/impala/hiveserver2.py", line 304, in execute
    self._wait_to_finish()  # make execute synchronous
  File "/usr/lib/python2.7/site-packages/impala/hiveserver2.py", line 380, in _wait_to_finish
    raise OperationalError(resp.errorMessage)
OperationalError: Error while processing statement: FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.spark.SparkTask
explained well here https://issues.apache.org/jira/browse/HIVE-12650
Try setting this at the code level or in hive-site.xml
My busy cluster has jobs queued for upto 10 mins at times, so I'm going to try setting the above timeout values to 900000 and monitor. Will share the results to see if it reduces the failures for my Hive on Spark jobs
Hi,
Any update on this? Is this issue resolved? if yes, please let us know the solution, we are also facing the same issue.
