Problem to run Recommendation system notebook with spark 2.3
I downloaded this ReS notebook from : https://ibm.ent.box.com/s/tx7tg2vshw3ev5l47bte6cehp32i17h2
and I tried to execute it with Spark 2.3, with the kernel Apache Toree0.2.0 dev1, Scala 2.12.
We were unable to execute the following cell:
ratings.sample (false, 0.0001, seed=0).show(10)
The issue is that we have the following error message that appears:
Message: Job aborted due to stage failure: Task 0 in stage 15.0 failed 1 times, most recent failure: Lost task 0.0 in stage 15.0 (TID 18, localhost, executor driver): java.lang.ClassCastException: $line227.$read$$iw$$iw$Rating cannot be cast to $line227.$read$$iw$$iw$Rating
        at org.apache.spark.sql.catalyst.expressions.GeneratedClass$GeneratedIteratorForCodegenStage1.processNext(Unknown Source)
        at org.apache.spark.sql.execution.BufferedRowIterator.hasNext(BufferedRowIterator.java:43)
        at org.apache.spark.sql.execution.WholeStageCodegenExec$$anonfun$10$$anon$1.hasNext(WholeStageCodegenExec.scala:614)
        at org.apache.spark.sql.execution.SparkPlan$$anonfun$2.apply(SparkPlan.scala:253)
        at org.apache.spark.sql.execution.SparkPlan$$anonfun$2.apply(SparkPlan.scala:247)
        at org.apache.spark.rdd.RDD$$anonfun$mapPartitionsInternal$1$$anonfun$apply$25.apply(RDD.scala:830)
        at org.apache.spark.rdd.MapPartitionsRDD.compute(MapPartitionsRDD.scala:38)
        at org.apache.spark.rdd.RDD.computeOrReadCheckpoint(RDD.scala:324)
        at org.apache.spark.rdd.RDD.iterator(RDD.scala:288)
        at org.apache.spark.scheduler.ResultTask.runTask(ResultTask.scala:87)
        at org.apache.spark.scheduler.Task.run(Task.scala:109)
        at org.apache.spark.executor.Executor$TaskRunner.run(Executor.scala:345)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
 Any help please to execute this notebook Thx
