Spark insert using hivecontext failing in spark submit
HI ,
insert statement failing in spark-submit but works fine in spark-shell
Exception in thread "main" java.lang.NoSuchMethodException: org.apache.hadoop.hive.ql.metadata.Hive.loadDynamicPartitions(org.apache.hadoop.fs.Path, java.lang.String, java.util.Map, boolean, int, boolean, boolean, boolean)
at java.lang.Class.getMethod(Class.java:1786)
at org.apache.spark.sql.hive.client.Shim.findMethod(HiveShim.scala:114)
at org.apache.spark.sql.hive.client.Shim_v0_14.loadDynamicPartitionsMethod$lzycompute(HiveShim.scala:404)
at org.apache.spark.sql.hive.client.Shim_v0_14.loadDynamicPartitionsMethod(HiveShim.scala:403)
at org.apache.spark.sql.hive.client.Shim_v0_14.loadDynamicPartitions(HiveShim.scala:455)
at org.apache.spark.sql.hive.client.ClientWrapper$$anonfun$loadDynamicPartitions$1.apply$mcV$sp(ClientWrapper.scala:577)
at org.apache.spark.sql.hive.client.ClientWrapper$$anonfun$loadDynamicPartitions$1.apply(ClientWrapper.scala:577)
at org.apache.spark.sql.hive.client.ClientWrapper$$anonfun$withHiveState$1.apply(ClientWrapper.scala:293)
at org.apache.spark.sql.hive.client.ClientWrapper.liftedTree1$1(ClientWrapper.scala:239)
at org.apache.spark.sql.hive.client.ClientWrapper.retryLocked(ClientWrapper.scala:238)
at org.apache.spark.sql.hive.client.ClientWrapper.withHiveState(ClientWrapper.scala:281)
at org.apache.spark.sql.hive.client.ClientWrapper.loadDynamicPartitions(ClientWrapper.scala:576)
at org.apache.spark.sql.hive.execution.InsertIntoHiveTable.sideEffectResult$lzycompute(InsertIntoHiveTable.scala:225)
at org.apache.spark.sql.hive.execution.InsertIntoHiveTable.sideEffectResult(InsertIntoHiveTable.scala:127)
at org.apache.spark.sql.hive.execution.InsertIntoHiveTable.doExecute(InsertIntoHiveTable.scala:276)
at org.apache.spark.sql.execution.SparkPlan$$anonfun$execute$5.apply(SparkPlan.scala:132)
at org.apache.spark.sql.execution.SparkPlan$$anonfun$execute$5.apply(SparkPlan.scala:130)
at org.apache.spark.rdd.RDDOperationScope$.withScope(RDDOperationScope.scala:150)
at org.apache.spark.sql.execution.SparkPlan.execute(SparkPlan.scala:130)
at org.apache.spark.sql.execution.QueryExecution.toRdd$lzycompute(QueryExecution.scala:55)
at org.apache.spark.sql.execution.QueryExecution.toRdd(QueryExecution.scala:55)
at org.apache.spark.sql.DataFrame.<init>(DataFrame.scala:145)
at org.apache.spark.sql.DataFrame.<init>(DataFrame.scala:130)
at org.apache.spark.sql.DataFrame$.apply(DataFrame.scala:52)
at org.apache.spark.sql.SQLContext.sql(SQLContext.scala:817)
at com.tiaa.spark.demotab.Demographics_Crosstag_Spark.main(Demographics_Crosstag_Spark.java:103)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.spark.deploy.SparkSubmit$.org$apache$spark$deploy$SparkSubmit$$runMain(SparkSubmit.scala:729)
at org.apache.spark.deploy.SparkSubmit$.doRunMain$1(SparkSubmit.scala:181)
at org.apache.spark.deploy.SparkSubmit$.submit(SparkSubmit.scala:206)
at org.apache.spark.deploy.SparkSubmit$.main(SparkSubmit.scala:121)
