Support Questions
SparkSQL key not found: scale
Hadoop version is 2.6.0-cdh.5.8.3.
Spark version is 1.6.0 with Scala version 2.10.5
I trying to do a simple SQL query to the remote Oracle 11g DB by using Spark SQL in spark-shell.
val jdbcDF = sqlContext.read.format("jdbc").options(
Map("url" -> "jdbc:oracle:thin:system/system@db-host:1521:orcl",
"dbtable"-> "schema_name.table_name",
"driver"-> "oracle.jdbc.OracleDriver",
"username" -> "user",
"password" -> "pwd")).load()
the result is:
java.util.NoSuchElementException: key not found: scale
    at scala.collection.MapLike$class.default(MapLike.scala:228)
    at scala.collection.AbstractMap.default(Map.scala:58)
    at scala.collection.MapLike$class.apply(MapLike.scala:141)
    at scala.collection.AbstractMap.apply(Map.scala:58)
    at org.apache.spark.sql.types.Metadata.get(Metadata.scala:108)
    at org.apache.spark.sql.types.Metadata.getLong(Metadata.scala:51)
    at org.apache.spark.sql.jdbc.OracleDialect$.getCatalystType(OracleDialect.scala:33)
    at org.apache.spark.sql.execution.datasources.jdbc.JDBCRDD$.resolveTable(JDBCRDD.scala:140)
    at org.apache.spark.sql.execution.datasources.jdbc.JDBCRelation.<init>(JDBCRelation.scala:91)
    at org.apache.spark.sql.execution.datasources.jdbc.DefaultSource.createRelation(DefaultSource.scala:57)
    at org.apache.spark.sql.execution.datasources.ResolvedDataSource$.apply(ResolvedDataSource.scala:158)
    at org.apache.spark.sql.DataFrameReader.load(DataFrameReader.scala:119)
    at $iwC$$iwC$$iwC$$iwC$$iwC$$iwC$$iwC$$iwC.<init>(<console>:25)
    at $iwC$$iwC$$iwC$$iwC$$iwC$$iwC$$iwC.<init>(<console>:30)
    at $iwC$$iwC$$iwC$$iwC$$iwC$$iwC.<init>(<console>:32)
    at $iwC$$iwC$$iwC$$iwC$$iwC.<init>(<console>:34)
    at $iwC$$iwC$$iwC$$iwC.<init>(<console>:36)
    at $iwC$$iwC$$iwC.<init>(<console>:38)
    at $iwC$$iwC.<init>(<console>:40)
    at $iwC.<init>(<console>:42)
    at <init>(<console>:44)
    at .<init>(<console>:48)
    at .<clinit>(<console>)
    at .<init>(<console>:7)
    at $print(<console>)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.apache.spark.repl.SparkIMain$ReadEvalPrint.call(SparkIMain.scala:1045)
    at org.apache.spark.repl.SparkIMain$Request.loadAndRun(SparkIMain.scala:1326)
    at org.apache.spark.repl.SparkIMain.loadAndRunReq$1(SparkIMain.scala:821)
    at org.apache.spark.repl.SparkIMain.interpret(SparkIMain.scala:852)
    at org.apache.spark.repl.SparkIMain.interpret(SparkIMain.scala:800)
    at org.apache.spark.repl.SparkILoop.reallyInterpret$1(SparkILoop.scala:857)
    at org.apache.spark.repl.SparkILoop.interpretStartingWith(SparkILoop.scala:902)
    at org.apache.spark.repl.SparkILoop.command(SparkILoop.scala:814)
    at org.apache.spark.repl.SparkILoop.processLine$1(SparkILoop.scala:657)
    at org.apache.spark.repl.SparkILoop.innerLoop$1(SparkILoop.scala:665)
    at org.apache.spark.repl.SparkILoop.org$apache$spark$repl$SparkILoop$$loop(SparkILoop.scala:670)
    at org.apache.spark.repl.SparkILoop$$anonfun$org$apache$spark$repl$SparkILoop$$process$1.apply$mcZ$sp(SparkILoop.scala:997)
    at org.apache.spark.repl.SparkILoop$$anonfun$org$apache$spark$repl$SparkILoop$$process$1.apply(SparkILoop.scala:945)
    at scala.tools.nsc.util.ScalaClassLoader$.savingContextLoader(ScalaClassLoader.scala:135)
    at org.apache.spark.repl.SparkILoop.org$apache$spark$repl$SparkILoop$$process(SparkILoop.scala:945)
    at org.apache.spark.repl.SparkILoop.process(SparkILoop.scala:1064)
    at org.apache.spark.repl.Main$.main(Main.scala:31)
    at org.apache.spark.repl.Main.main(Main.scala)
    at org.apache.spark.deploy.SparkSubmit$.org$apache$spark$deploy$SparkSubmit$$runMain(SparkSubmit.scala:731)
    at org.apache.spark.deploy.SparkSubmit$.doRunMain$1(SparkSubmit.scala:181)
    at org.apache.spark.deploy.SparkSubmit$.submit(SparkSubmit.scala:206)
    at org.apache.spark.deploy.SparkSubmit$.main(SparkSubmit.scala:121)
Can someone tell me, what is the reason of such error?
1 ACCEPTED SOLUTION
Expert Contributor
This is currently an issue with Numeric datatypes.  This is resolved in 2.0, but you can work around the issue by casting to Varchar or importing data into an RDD then converting to DataFrame.
4 REPLIES 4
Expert Contributor
Can you explain how to do that briefly.
I'm trying to connect to oracle database to bring the count of the table from source and compare with the data moved to destination table in hive for validation.
Thanks
As i don't know the columns which are numeric in source table.
We are also facing the same issue. Is there any solution now?
