Rod
Accepted Solution
Will Spark SQL be officially supported in CDH6.0?
Since the spark sql binary is not shipped with CDH6.0 I wonder whether it is officially supported.
Topics: 14
Kudos: 91
Solutions: 45
Re: Will Spark SQL be officially supported in CDH6.0?
@Rod
CDH 6.0 will support Spark 2.2.0 and Spark 2.2.0 will support Spark SQL as per below link
https://spark.apache.org/docs/2.2.0/sql-programming-guide.html#sql
Not sure this is the answer for your question, if not, please give some more details
Rod
[ Edited ]
Well... that means it might work. My question is more whether it is going to be officially supported by Cloudera. In the sense that if some problems or incompatibilities are found Cloudera will be responsible for fixing them. To be more precise I am asking about Spark SQL CLI.
Rod
The question refers in particular to Spark SQL CLI. As of now, the Spark SQL CLI is not shipped with CDH6 and it is known to NOT be supported in some of the previous versions. Is it supported in CDH6?
Cloudera Employee
@Rod No, it is unsupported (as of writing) in both CDH5 and CDH6.
https://www.cloudera.com/documentation/enterprise/6/release-notes/topics/rg_cdh_600_unsupported_feat...
Spark SQL CLI is not supported
