Cloudera Employee
Re: Wrong spark history redirection for finished jons
No, I meant the gateway role or if needed spark history server role where you don't see spark-default.conf having a correct config.
Gateway role is better. If you don't want to delete. Just add a new gateway role from CM->Spark->Instances and then see if then configuration comes correct.
Expert Contributor
Hi @neerjakhattar
1- removed all instances from spark gateway, deployed configuration and then added the servers to the gatway and deployed the configuration but this didn't help.
2- checked all the luster instances and see the new spark history server in all spark-default.conf and no servers has any other configuration.
cat /etc/spark/conf/spark-defaults.conf | grep spark.yarn.historyServer.address
spark.yarn.historyServer.address=http://avvr-ahc101.lpdomain.com:18088
3- the valve CM config is empty.
Where these conf can be overwritten in some other places?
Expert Contributor
any new insights?
Expert Contributor
Don't know the exact cause that it was not working even i restarted the Yarn, when i had another chance to restart the Yarn, the issue was resolved.
