Accepted Solution
first steps with Spark and Hue
[ Edited ]
Hello! I am tying to run a Spark script in hue:
Name of my script: SparkTest.py
Content of my script:
text_file = sc.textFile("hdfs://...testFile.txt")
counts = text_file.flatMap(lambda line: line.split(" ")) \
  .map(lambda word: (word, 1)) \
  .reduceByKey(lambda a, b: a + b)
  counts.saveAsTextFile("hdfs://...RESULT.txt")
Content of my testFile:
Test Test
Problem:
After running of this script my RESULT.txt file is still empty.
Question:
- Which Spark/Hue configuration do I need to run simple Spark scripts with the help of hue?
I use VM Cloudera 5.13
Thank you!
Master
Re: first steps with Spark and Hue
It is hard to tell from this what can be the problem. Can you post the spark logs, do you have access to the Spark job UI? Do you get some error messages?
I have added SparkContext to my script:
from pyspark import SparkContext, SparkConf
conf = SparkConf().setAppName(appNameTEST).setMaster(master)
sc = SparkContext(conf=conf)
Most relevant error log in hue:
  File "/yarn/nm/usercache/cloudera/appcache/application_1542723589859_0008/container_1542723589859_0008_01_000002/SparkTest.py", line 3, in <module>
NameError: name 'appNameTEST' is not defined
Less relevant error:
2018-11-20 08:07:59,555 [DataStreamer for file /user/cloudera/oozie-oozi/0000003-181120074347071-oozie-oozi-W/spark2-b3ea--spark/action-data.seq] WARN  org.apache.hadoop.hdfs.DFSClient  - Caught exception
java.lang.InterruptedException
    at java.lang.Object.wait(Native Method)
    at java.lang.Thread.join(Thread.java:1281)
    at java.lang.Thread.join(Thread.java:1355)
    at org.apache.hadoop.hdfs.DFSOutputStream$DataStreamer.closeResponder(DFSOutputStream.java:967)
    at org.apache.hadoop.hdfs.DFSOutputStream$DataStreamer.endBlock(DFSOutputStream.java:705)
    at org.apache.hadoop.hdfs.DFSOutputStream$DataStreamer.run(DFSOutputStream.java:894)
Master
NameError: name 'appNameTEST' is not defined -> that is a syntax error, python does not know any variable with this name
Thank you, you are right. How can set a variable in python for Spark?
I thought that "conf = SparkConf().setAppName(appNameTEST).setMaster(master)" would set this variable?
Master
It is a normal python :-)
Just use myvariable = "value", so
app_name = "My gorgeous application"
conf = SparkConf().setAppName(app_name).setMaster(master)
Thank you!
I have change it.
Also I have changed my paths. Because the path is for directory and not for a file. I have also added a / to my path. Now I get results which I have expected. I changed "setMaster to "local" because it is just a small Cloudera VM without cluster.
This is a simple Spark script which can be executed in hue per Spark editor:
appNameTEST ="my first working application"
conf = SparkConf().setAppName(appNameTEST).setMaster("local")
text_file = sc.textFile("hdfs:///user/hive/warehouse/TEST/FilePath")
counts.saveAsTextFile("hdfs:///user/hive/warehouse/TEST/RESULT")
