json case some match is working fine in spark shell and not in spark-submit
 please find the below code:
"result" is the type of scala.Some
result match {
case Some(map: Map[String, Any]) => {
println(" block one::")
val error = map("error")
println("error-->" + error)
the above code is working fine in spark-shell but not working using spark-submit with jar file.
spark-submit --driver-memory 3G --executor-memory 3G --num-executors 3 --executor-cores 3 --class com.hcl.spark.SampleHttp --master yarn-cluster /home/eih/prod/usermdm/jars/code/spark_ad_ingestion.jar
Appreciate your help as soon as possible
Cloudera Employee
Re: json case some match is working fine in spark shell and not in spark-submit
Hello Sreeja,
Thank you for posting your query
Could you please pass some addtional information related to this issue ?
Example.
1. Error message which you are seeing
2. How you are compiling / executing this code etc.,
Thanks,
Satz
Thanks,
Satz
