Exceeded MAX_FAILED_UNIQUE_FETCHES; bailing-out
Hi, Team
I have a problem when querying select count(*) from table atau select distinct field from table atau select * from table order by field.
when checked through yarn, then application details.
error appears :
2017-10-03 16:22:54,826 INFO [IPC Server handler 12 on 35262] org.apache.hadoop.mapred.TaskAttemptListenerImpl: Progress of TaskAttempt attempt_1506588001647_0368_r_000000_0 is : 0.21282798
2017-10-03 16:22:54,827 FATAL [IPC Server handler 10 on 35262] org.apache.hadoop.mapred.TaskAttemptListenerImpl: Task: attempt_1506588001647_0368_r_000000_0 - exited : org.apache.hadoop.mapreduce.task.reduce.Shuffle$ShuffleError: error in shuffle in fetcher#3
at org.apache.hadoop.mapreduce.task.reduce.Shuffle.run(Shuffle.java:134)
at org.apache.hadoop.mapred.ReduceTask.run(ReduceTask.java:376)
at org.apache.hadoop.mapred.YarnChild$2.run(YarnChild.java:164)
at javax.security.auth.Subject.doAs(Subject.java:422)
at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1709)
at org.apache.hadoop.mapred.YarnChild.main(YarnChild.java:158)
Caused by: java.io.IOException: Exceeded MAX_FAILED_UNIQUE_FETCHES; bailing-out.
at org.apache.hadoop.mapreduce.task.reduce.ShuffleSchedulerImpl.checkReducerHealth(ShuffleSchedulerImpl.java:391)
at org.apache.hadoop.mapreduce.task.reduce.ShuffleSchedulerImpl.copyFailed(ShuffleSchedulerImpl.java:306)
at org.apache.hadoop.mapreduce.task.reduce.Fetcher.openShuffleUrl(Fetcher.java:294)
at org.apache.hadoop.mapreduce.task.reduce.Fetcher.copyFromHost(Fetcher.java:335)
at org.apache.hadoop.mapreduce.task.reduce.Fetcher.run(Fetcher.java:198)
can be helped on this
Many Thanks
Champion
Re: Exceeded MAX_FAILED_UNIQUE_FETCHES; bailing-out
could you fire the below commands in master and slave
netstat -anp | grep 50060
also see if you can ping your slave from master and vice versa
looks like issue between them
Hi csguna
Thanks For Support, can be explained, just host Task Tracker or include the master host, because if not the host task tracker status closed ?
what about the host job tracker, where the port is 50030, if the check must be closed port ?
