Contributor
Accepted Solution
Error while CDH installation from cloudera manager using installation path A
[ Edited ]
->Cloudera manager installation-done for 2 servers
->HA done
->CDH installation for one manager-done
->CDH installation for 32 servers-error
/tmp/scm_prepare_node.Ephf7nOy
using SSH_CLIENT to get the SCM hostname: 10.*.*.44 37998 22
opening logging file descriptor
Starting installation script...
Acquiring installation lock...
BEGIN flock 4
END (0)
Detecting root privileges...
effective UID is 0
Detecting distribution...
BEGIN grep Tikanga /etc/redhat-release
END (1)
BEGIN grep 'CentOS release 5' /etc/redhat-release
END (1)
BEGIN grep 'Scientific Linux release 5' /etc/redhat-release
END (1)
BEGIN grep Santiago /etc/redhat-release
END (1)
BEGIN grep 'CentOS Linux release 6' /etc/redhat-release
END (1)
BEGIN grep 'CentOS release 6' /etc/redhat-release
END (1)
BEGIN grep 'Scientific Linux release 6' /etc/redhat-release
END (1)
BEGIN grep Maipo /etc/redhat-release
END (1)
BEGIN grep 'CentOS Linux release 7' /etc/redhat-release
CentOS Linux release 7.2.1511 (Core)
END (0)
/etc/redhat-release ==> CentOS 7
Detecting Cloudera Manager Server...
BEGIN host -t PTR 10.*.*.44
Host 44.*.*.10.in-addr.arpa. not found: 3(NXDOMAIN)
END (1)
BEGIN which python
/usr/bin/python
END (0)
BEGIN python -c 'import socket; import sys; s = socket.socket(socket.AF_INET); s.settimeout(5.0); s.connect((sys.argv[1], int(sys.argv[2]))); s.close();' 10.*.*.44 7182
File "<string>", line 1, in <module>
File "/usr/lib64/python2.7/socket.py", line 224, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 113] No route to host
END (1)
could not contact scm server at 10.*.*.44:7182, giving up
waiting for rollback request
Cloudera Employee
Re: Error while CDH installation from cloudera manager using installation path A
Hi Divyani, it seems that you have set the IP "10.*.*.44" for the Cloudera Manager server (cloudera-scm-server). Can you set the correct IP or hostname for the "server_host" parameter in the /etc/cloudera-scm-agent/config.ini file?
I am getting the same kind of error. and not able to get the config.ini file i the /etc/cloudera-scm-server folder.
Champion
@Divyani @Sats
did you install the cloudera-manager-server and cloudera-manager-agent rpm ?
the default config file path would be
change the server_host
Champion
[ Edited ]
@Sats
if you want to change any thing in the cloudera manager config
checkout  the below path
/etc/default/cloudera-scm-server
Hi @csguna
Below is what i could see in the
Not sure where to make the server host change. Kindly let me know your inputs.
# Specify any command line arguments for the Cloudera SCM Server here.
CMF_SERVER_ARGS=""
# Locate the JDBC driver jar file.
# The default value is the default system mysql driver on RHEL/CentOS/Ubuntu
# and the standard, documented location for where to put the oracle jar in CM
# deployments.
export CMF_JDBC_DRIVER_JAR="/usr/share/java/mysql-connector-java.jar:/usr/share/java/oracle-connector-java.jar"
# Java Options.
# Default value sets Java maximum heap size to 2GB, and Java maximum permanent
# generation size to 256MB.
export CMF_JAVA_OPTS="-Xmx2G -XX:MaxPermSize=256m -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=/tmp"
Champion
[ Edited ]
@Sats
Could you check the below path , thats were you can change the server_host -
, if you did not find one that means you havent installed cloudera scm agent
Contributor
Hi All,
Thank you for your resolution. I was able to resolve the issue. The issue was with /etc/hosts file and the firewall service was also running, so stopped that as well.
