Contributor
Accepted Solution
Impala 32Bit vs 64bit ODBC
Hi,
I've got a user who's 32bit ODBC impala connection is fine, but the 64bit gives the the "unspeficied GSS error"
There is no difference between the two connections and no one else is epereincing this problem.
Any ideas?!?!
Cloudera Employee
Re: Impala 32Bit vs 64bit ODBC
Its difficult to say what might be going on without more information, but a few pieces of info  that may be helpful to you:
- "Unspecified GSS error" generally indicates an issue with Kerberos authentication.
- The bitness of the ODBC driver must match the bitness of the client application in order for everything to work correctly.
From your description, it may be that the user is using a 32bit Kerberos client, in which case it is expected that the 64bit ODBC driver would not work with it.
Given that the 32bit connection is fine, what's the motivation for trying to get the 64 bit driver to work?
Contributor
Hi,
It was when acctually setting up the ODBC within windows.
Create ODBC within windows DSN 32 bit works ok.  It's the creating an ODBC within 64bit that doesnt.
There is no client applicaiton even involved at this point yet.
On my machine both 32/64bit can be created, so there must be something different on this users windows machine, i'm stumped!
Contributor
Just incase anyone has this problem in the future, the issue was reolved by enabling "Enable for this DSN" option under use only SSPI inside the advanced options.
I'm not sure why this user needed to do that and no other use has, but seems to have worked.
