Accepted Solution
Impala and unicode (displaying issue)
[ Edited ]
Hi, all!
I'am using impyla(python labrary) to insert data to Impala and all the strings are in unicode format.
All the tables have STRING format of the fields.
But i can't see unicode symbols using select statement from client(using jdbc or odbc driver).
How can I handle it?
Thanks
Cloudera Employee
Re: Impala and unicode (displaying issue)
Impala does not fully support Unicode. See "Character Sets" here:
https://www.cloudera.com/documentation/enterprise/latest/topics/impala_string.html
That said, reading/writing UTF-8 should work in most circumstances. Is your data in UTF-8 or a different representation of Unicode? Other encodings will likely not work at all.
Do queries using the Impala Shell return expected results?
I've read everything related to data types in Impala
But finally, I found out that the problem was in SQL query constructing on Python side.
Cloudera Employee
Thanks for following up! Do you mind summarizing the changes you made to fix it so others can benefit from your solution?
