Accepted Solution
Hub Web UI doesn't work
[ Edited ]
Hi,  I have a cluster witn CDH 5.4.2,  and the whole cluster is working fine, but when I try to access to the Hue Web UI doesn't work, ( https://host:7180/cmf/services/23/status ) when I go to https://host:8888 , it doesn't work.. ( it looks like a ERR_CONNECTION_TIMED_OUT error )   I got the next error at the Log from Hue.
5:37:45 AM INFO settings Welcome to Hue 3.7.0
5:37:46 AM WARNING __init__ Couldn't import snappy. Support for snappy compression disabled.[09/Jun/2015 20:00:13 ] settings INFO Welcome to Hue 3.7.0
6:00:14 AM WARNING __init__ Couldn't import snappy. Support for snappy compression disabled.
6:00:14 AM INFO settings Welcome to Hue 3.7.0
6:00:15 AM WARNING __init__ Couldn't import snappy. Support for snappy compression disabled.
do you have any idea ?
Cloudera Employee
Re: Hub Web UI doesn't work
Could we get more log information about the Hue services? (the lines above
are just warnings when snappy is not installed and does not matter).
What is the health of Hue too in CM?
Romain
Hi,
Thanks for your answerd, but I find out that it's something wrong with the gateway or something.
I can reach port 7180 .. that is for Cloudera Manager,
But I can not reach Ports:
8888 - for Hue
50070 - for HDFS
8983 - for Solr ( also .. ports for Impala, Yarn )
those ports I already add as a DNAT rule,
when I did a telnet test ... to those specifict ports.. I got an
HTTP/1.1 408 Request Timeout
nd the health of the whole CM is ok .. ( all the programs, are working fine.. they have green light )
also I restart the CM , twice, in order to test it.. but I still got the same error..
Cloudera Employee
Hum, seems like you have a firewall issue or something like that
actually i get
Clock Offset
on the whole clusters
but when i try to updated
$ sudo ntpdate pool.ntp.org
$ sudo service ntp stop
$ sudo service ntp start
i got an error
no server suitable for synchronization found
also i try the next..
 $ sudo ntpdate ntp.ubuntu.com
**** ntpdate[1258]: no server suitable for synchronization found
**** ntpdate[1267]: no server suitable for synchronization found
$ sudo ntpdate de.pool.ntp.org
**** ntpdate[1273]: no server suitable for synchronization found
$ sudo ntpdate us.pool.ntp.org
**** ntpdate[1276]: no server suitable for synchronization found
do you have any suggest?
I got these WARN in kt renewer under hue log and after two hours of troubleshooting learnt that the PID on Cloudera Monitoring serverices had some conflicts.
Had to stop Cloudera Monitor services
restart cloudera-scm-server and agent
It did all the magic.
Issue resolved..
It might be different for others, though.
There was no Firewall issue for me.
[ Edited ]
Facing the same issue. Can't connect to the other ports like
8888 - for Hue
50070 - for HDFS
When try to open hue web ui.... its saying "
This site can’t be reached
gke-hadoop-ubuntu-default-pool-78514257-626p.c.platform-services.internal’s server DNS address could not be found.
Please help.
Topics: 1
Kudos: 244
Solutions: 126
@frankenstein, "server DNS address could not be found." indicates that your configured DNS servers on the browser host cannot resolve your hostname.  Make sure gke-hadoop-ubuntu-default-pool-78514257-626p.c.platform-services.internal  can be resolved to an IP address on your browser host.
