Re: Hub Web UI doesn't work
@bgooley "How to resolve the hostname on browser host. Can you please explain the solution in detail."
In putty connected to the master instace and performed ping gke-hadoop-ubuntu-default-pool-78514257-626p.c.platform-services.internal ..... its responding. Also performed curl http://gke-hadoop-ubuntu-default-pool-78514257-626p.c.platform-services.internal:10002/ (my hue server is down so tried connecting to hive having 10002 port) got this:
I think in putty its connected but in browser its not resolving the hostname....
Topics: 1
Kudos: 158
Solutions: 83
@Genthandsome,
I'm talking about DNS.
https://en.wikipedia.org/wiki/Domain_Name_System
For instance, if using a DNS server for name resolution:
$ nslookup www.google.com
Server:        x.x.x.x
Address:    x.x.x.x#53
Non-authoritative answer:
Address: 172.217.0.36
My point in this case is that someone got an error saying that the browser could not resolve the IP.
For example, see:
https://stackoverflow.com/questions/36668374/how-do-i-solve-the-server-dns-address-could-not-be-foun...
The browser problem showed an issue with the browser and how it tries to communicate with the server host; it had nothing to do with Hue.
Topics: 1
Kudos: 158
Solutions: 83
@Genthandsome,
Actually, that stackoverflow may be off target since it talks about public addresses.  Your browser needs to resolve a hostname into an IP so that your computer can connect to Hue.  If that resolution (or mapping) fails then the client (browser in this case) cannot connect to the host specified in the browser's URL.
