Jug
[CDH 5.3] Hive context error while using a pyspark script
I installed CDH 5.3 and I am running a pyspark program to create a table in hive but seems that I am running into following error:
2015-02-09 06:42:39,513 ERROR [Thread-2] metastore.RetryingHMSHandler (RetryingHMSHandler.java:invoke(144)) - MetaException(message:file:/user/hive/warehouse/src2 is not a directory or unable to create one)
at org.apache.hadoop.hive.metastore.HiveMetaStore$HMSHandler.create_table_core(HiveMetaStore.java:1248)
at org.apache.hadoop.hive.metastore.HiveMetaStore$HMSHandler.create_table_with_environment_context(HiveMetaStore.java:1303)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.apache.hadoop.hive.metastore.RetryingHMSHandler.invoke(RetryingHMSHandler.java:106)
at com.sun.proxy.$Proxy15.create_table_with_environment_context(Unknown Source)
at org.apache.hadoop.hive.metastore.HiveMetaStoreClient.createTable(HiveMetaStoreClient.java:569)
at org.apache.hadoop.hive.metastore.HiveMetaStoreClient.createTable(HiveMetaStoreClient.java:558)
at org.apache.hadoop.hive.metastore.RetryingMetaStoreClient.invoke(RetryingMetaStoreClient.java:90)
at com.sun.proxy.$Proxy16.createTable(Unknown Source)
at org.apache.hadoop.hive.ql.metadata.Hive.createTable(Hive.java:637)
at org.apache.hadoop.hive.ql.exec.DDLTask.createTable(DDLTask.java:4241)
at org.apache.hadoop.hive.ql.exec.DDLTask.execute(DDLTask.java:284)
at org.apache.hadoop.hive.ql.exec.Task.executeTask(Task.java:153)
at org.apache.hadoop.hive.ql.exec.TaskRunner.runSequential(TaskRunner.java:85)
at org.apache.hadoop.hive.ql.Driver.launchTask(Driver.java:1554)
at org.apache.hadoop.hive.ql.Driver.execute(Driver.java:1321)
at org.apache.hadoop.hive.ql.Driver.runInternal(Driver.java:1139)
at org.apache.hadoop.hive.ql.Driver.run(Driver.java:962)
at org.apache.hadoop.hive.ql.Driver.run(Driver.java:952)
at org.apache.spark.sql.hive.HiveContext.runHive(HiveContext.scala:305)
at org.apache.spark.sql.hive.HiveContext.runSqlHive(HiveContext.scala:276)
at org.apache.spark.sql.hive.execution.NativeCommand.sideEffectResult$lzycompute(NativeCommand.scala:35)
at org.apache.spark.sql.hive.execution.NativeCommand.sideEffectResult(NativeCommand.scala:35)
at org.apache.spark.sql.execution.Command$class.execute(commands.scala:46)
at org.apache.spark.sql.hive.execution.NativeCommand.execute(NativeCommand.scala:30)
at org.apache.spark.sql.SQLContext$QueryExecution.toRdd$lzycompute(SQLContext.scala:425)
at org.apache.spark.sql.SQLContext$QueryExecution.toRdd(SQLContext.scala:425)
at org.apache.spark.sql.SchemaRDDLike$class.$init$(SchemaRDDLike.scala:58)
at org.apache.spark.sql.SchemaRDD.<init>(SchemaRDD.scala:108)
at org.apache.spark.sql.hive.HiveContext.sql(HiveContext.scala:94)
at py4j.reflection.MethodInvoker.invoke(MethodInvoker.java:231)
at py4j.reflection.ReflectionEngine.invoke(ReflectionEngine.java:379)
at py4j.Gateway.invoke(Gateway.java:259)
at py4j.commands.AbstractCommand.invokeMethod(AbstractCommand.java:133)
at py4j.commands.CallCommand.execute(CallCommand.java:79)
at py4j.GatewayConnection.run(GatewayConnection.java:207)
2015-02-09 06:42:39,553 ERROR [Thread-2] exec.DDLTask (DDLTask.java:execute(481)) - org.apache.hadoop.hive.ql.metadata.HiveException: MetaException(message:file:/user/hive/warehouse/src2 is not a directory or unable to create one)
at org.apache.hadoop.hive.ql.metadata.Hive.createTable(Hive.java:643)
Caused by: MetaException(message:file:/user/hive/warehouse/src2 is not a directory or unable to create one)
... 31 more
2015-02-09 06:42:39,572 ERROR [Thread-2] ql.Driver (SessionState.java:printError(565)) - FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.DDLTask. MetaException(message:file:/user/hive/warehouse/src2 is not a directory or unable to create one)
2015-02-09 06:42:39,583 INFO  [Thread-2] log.PerfLogger (PerfLogger.java:PerfLogEnd(135)) - </PERFLOG method=Driver.execute start=1423492958974 end=1423492959583 duration=609 from=org.apache.hadoop.hive.ql.Driver>
2015-02-09 06:42:39,583 INFO  [Thread-2] log.PerfLogger (PerfLogger.java:PerfLogBegin(108)) - <PERFLOG method=releaseLocks from=org.apache.hadoop.hive.ql.Driver>
2015-02-09 06:42:39,584 INFO  [Thread-2] log.PerfLogger (PerfLogger.java:PerfLogEnd(135)) - </PERFLOG method=releaseLocks start=1423492959583 end=1423492959584 duration=1 from=org.apache.hadoop.hive.ql.Driver>
2015-02-09 06:42:39,705 ERROR [Thread-2] hive.HiveContext (Logging.scala:logError(75)) -
HIVE FAILURE OUTPUT
  File "<stdin>", line 1, in <module>
  File "/usr/lib/spark/python/pyspark/sql.py", line 1620, in sql
    return SchemaRDD(self._ssql_ctx.sql(sqlQuery).toJavaSchemaRDD(), self)
  File "/usr/lib/spark/python/lib/py4j-0.8.2.1-src.zip/py4j/java_gateway.py", line 538, in __call__
  File "/usr/lib/spark/python/lib/py4j-0.8.2.1-src.zip/py4j/protocol.py", line 300, in get_return_value
py4j.protocol.Py4JJavaErrorFAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.DDLTask. MetaException(message:file:/user/hive/warehouse/src2 is not a directory or unable to create one)
END HIVE FAILURE OUTPUT
: An error occurred while calling o17.sql.
: org.apache.spark.sql.execution.QueryExecutionException: FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.DDLTask. MetaException(message:file:/user/hive/warehouse/src2 is not a directory or unable to create one)
at org.apache.spark.sql.hive.HiveContext.runHive(HiveContext.scala:309)
