Connecting Oracle using Dataframe API
Hi,
With the format of url=“jdbc:oracle:thin:@dburl:port:sid” for oracle, and url = “jdbc:mysql://dburl:port/sid” for MySQL, they worked properly under scala. However under java its not working with below way.
DB_CONNECTION_URL = DB_URL+”:”+DB_PORT+”:”+DB_NAME+”,”+DB_USERNAME + “,” + DB_PWD;
DB_CONNECTION_URL = DB_URL+”:”+DB_PORT+”/”+DB_NAME+”?user=”+DB_USERNAME + “&password=” + DB_PWD;
Please find the samle code.
Map<String, String> options = new HashMap<>();
            options.put("driver", ORACLE_DRIVER);
            options.put("url", ORACLE_CONNECTION_URL);
            options.put("dbtable",
                        "(select * from emp) as data");
            options.put("partitionColumn", "emp_no");
            options.put("lowerBound", "396306");
            options.put("upperBound", "496306");
  DataFrame jdbcDF = sqlContext.load("jdbc", options);
I'm getting TNS Listner error for the first way
ORA-12514, TNS:listener does not currently know of service requested in connect descriptor
For second way
Exception in thread "main" java.sql.SQLRecoverableException: IO Error: NL Exception was generated.
Please help me out.
Regards,
Venkat
