SPARK Dataframe and IMPALA CREATE TABLE issue
Hi All, using spakr 1.6.1 to store data into IMPALA (read works without issues),
getting exception with table creation..when executed as below.
joined.write().mode(SaveMode.Overwrite).jdbc(DB_CONNECTION, DB_TABLE3, props);
Could anyone help on data type converion from TEXT to String and DOUBLE PRECISION to Double .
Cloudera Employee
Re: SPARK Dataframe and IMPALA CREATE TABLE issue
Hi Msdhan,
What's the schema and fileformat of the Impala table?  Why not write the data directly and avoid a jdbc connection to impala?
Jason
Thanks for the reply, The peace of code is mentioned below.
DataFrame right = sqlContext.read().jdbc(DB_CONNECTION, "testDB.tab2", props);
DataFrame joined = sqlContext.read().jdbc(DB_CONNECTION, "testDB.tab1", props).join(right, "id");
joined.write().jdbc(DB_CONNECTION, DB_TABLE3, props);
Its default file comma delimited format. Please find the full exception is mentioned below.
Exception in thread "main" java.sql.SQLException: [Simba][ImpalaJDBCDriver](500051) ERROR processing query/statement. Error Code: 0, SQL state: TStatus(statusCode:ERROR_STATUS, sqlState:HY000, errorMessage:AnalysisException: Syntax error in line 1:
....tab3 (id INTEGER , col_1 TEXT , col_2 DOUBLE PRECISIO...
Encountered: IDENTIFIER
Expected: ARRAY, BIGINT, BINARY, BOOLEAN, CHAR, DATE, DATETIME, DECIMAL, REAL, FLOAT, INTEGER, MAP, SMALLINT, STRING, STRUCT, TIMESTAMP, TINYINT, VARCHAR
CAUSED BY: Exception: Syntax error
), Query: CREATE TABLE testDB.tab3 (id INTEGER , col_1 TEXT , col_2 DOUBLE PRECISION , col_3 TIMESTAMP , col_11 TEXT , col_22 DOUBLE PRECISION , col_33 TIMESTAMP ).
at com.cloudera.hivecommon.api.HS2Client.executeStatementInternal(Unknown Source)
at com.cloudera.hivecommon.api.HS2Client.executeStatement(Unknown Source)
at com.cloudera.hivecommon.dataengine.HiveJDBCNativeQueryExecutor.executeHelper(Unknown Source)
at com.cloudera.hivecommon.dataengine.HiveJDBCNativeQueryExecutor.execute(Unknown Source)
at com.cloudera.jdbc.common.SStatement.executeNoParams(Unknown Source)
at com.cloudera.jdbc.common.SStatement.executeUpdate(Unknown Source)
at org.apache.spark.sql.DataFrameWriter.jdbc(DataFrameWriter.scala:302)
Caused by: com.cloudera.support.exceptions.GeneralException: [Simba][ImpalaJDBCDriver](500051) ERROR processing query/statement. Error Code: 0, SQL state: TStatus(statusCode:ERROR_STATUS, sqlState:HY000, errorMessage:AnalysisException: Syntax error in line 1:
... 7 more
Contributor
One way is to use selectExpr and use cast. val ConvertedDF = joined.selectExpr("id","cast(mydoublecol as double) mydoublecol");
Actually trying in java, as below
DataFrame updated = joined.selectExpr("id", "cast(col_1 as STRING) col_1", "cast(col_2 as DOUBLE) col_2", "cast(col_11 as STRING) col_11", "cast(col_22 as DOUBLE) col_22" );
updated.write().jdbc(DB_CONNECTION, DB_TABLE3, props);
Still shows the same error, any issue over here ?
Cloudera Employee
Why are you trying to connect to Impala via JDBC and write the data?  You can write the data directly to the storage through Spark and still access through Impala after calling "refresh <table>" in impala.  This will avoid the issues you are having and should be more performant.
thanks for the suggession, will try this.
Is there any way to avoid the above error?
Contributor
if writing to parquet you just have to do something like: df.write.mode("append").parquet("/user/hive/warehouse/Mytable") and if you want to prevent the "small file" problem: df.coalesce(1).write.mode("append").parquet("/user/hive/warehouse/Mytable")
How to integrate impala and spark using scala?
