Accepted Solution
WordCount failed by using Job Designer (using Quickstart VM)
Hi,
I use Quickstart VM.   The Wordcount runs fine.   However, I got error when I use Job Desinger to run the same java and textfile.   Oozie is up and running with Ext JS installed properly.   My job doucment - https://dl.dropboxusercontent.com/u/1814045/Job.docx   The error log - https://dl.dropboxusercontent.com/u/1814045/hue-1383608375.87.log  Any help is appreciated.   Thanks.
Regards,
Marco
Cloudera Employee abe
Cloudera Employee
Re: WordCount failed by using Job Designer (using Quickstart VM)
Hey there!
Are you sure '/home/cloudera/lab/wc.jar' exists? Also, are you sure your user has permission to access '/home/cloudera/lab/wc.jar'? Hue is having trouble copying that file.
-Abe
Cloudera Employee
I see a space after the file name, could you trim it in the design?
/home/cloudera/lab/wc.jar '
[04/Nov/2013 15:38:14 +0000] middleware   INFO     Processing exception: [Errno 2] Copy src '/home/cloudera/lab/wc.jar ' does not exist: Traceback (most recent call last):
  File "/usr/share/hue/build/env/lib/python2.6/site-packages/Django-1.2.3-py2.6.egg/django/core/handlers/base.py", line 100, in get_response
    response = callback(request, *callback_args, **callback_kwargs)
  File "/usr/share/hue/apps/oozie/src/oozie/decorators.py", line 52, in decorate
    return view_func(request, *args, **kwargs)
  File "/usr/share/hue/apps/oozie/src/oozie/views/editor.py", line 310, in submit_workflow
    job_id = _submit_workflow(request.user, request.fs, workflow, mapping)
  File "/usr/share/hue/apps/oozie/src/oozie/views/editor.py", line 331, in _submit_workflow
    job_id = submission.run()
  File "/usr/share/hue/desktop/libs/liboozie/src/liboozie/submittion.py", line 72, in run
    deployment_dir = self.deploy()
  File "/usr/share/hue/desktop/libs/liboozie/src/liboozie/submittion.py", line 152, in deploy
    self._do_as(self.user.username , self._copy_files, deployment_dir, oozie_xml)
  File "/usr/share/hue/desktop/libs/liboozie/src/liboozie/submittion.py", line 252, in _do_as
    return fn(*args, **kwargs)
  File "/usr/share/hue/desktop/libs/liboozie/src/liboozie/submittion.py", line 246, in _copy_files
    self.fs.copyfile(file, self.fs.join(lib_path, self.fs.basename(file)))
  File "/usr/share/hue/desktop/libs/hadoop/src/hadoop/fs/webhdfs.py", line 486, in copyfile
    raise IOError(errno.ENOENT, _("Copy src '%s' does not exist") % src)
IOError: [Errno 2] Copy src '/home/cloudera/lab/wc.jar ' does not exist
Good catch!   Thanks
Regards,
Marco
