oozie coordinators s3n path problem
[ Edited ]
Hello guys,
               I have installed the cloudera enterprise and  through HUE UI browser I can able to run my oozie workflow job my  input path as s3n://xxx-xxx/{YEAR}${MONTH}${DAY}/${HOUR} and output path (hdfs://...).When I coming to coordinators jobs as specfied the input
path through data-set (uri -template) as
s3n://xxx-xxx/{YEAR}${MONTH}${DAY}/${HOUR} its  preappend as
${nameNode}/user/${wf:user()}/s3n://ymxdata-test/${YEAR}${MONTH}${DAY}/${HOUR} like this.
help needed.This configuration through HUE only..
Cloudera Employee
Re: oozie coordinators s3n path problem
Shouldn't the data be copied from S3 to HDFS anyway?
(at least at the Oozie level: https://issues.apache.org/jira/browse/OOZIE-426)
Cloudera Employee
Yes, The data dependencies in a coordinator must be on HDFS.  However, the next version of Oozie will also allow it to be in HCatalog.
Software Engineer | Cloudera, Inc. | http://cloudera.com
(HUE Browser) But I can able to configure my  workflow job  input path as  s3n:// .why  can't be able to  configure the coordinator job dataset as s3n:// input path.
Kudos: 432
Solutions: 302
Possible dupe thread: http://community.cloudera.com/t5/Cloudera-Manager-Installation/Problem-in-oozie-input-path-How-do-I-...
Your issue is in your configuration. You need to remove the templated "${nameNode}/user/${wf:user()}/" in your workflow.xml if you are already passing a proper URI.
