Accepted Solution
Regex not giving same results as other regex engines
I'm executing the following query in Hive.  Many of my field values in my actual table look like:
ASDF (1)
abc 123 xyz (10)
etc. etc.  I just want to replace any digits in parentheses at the end of a string with "x".
select 'SP0724_FA (1)' as str, regexp_replace(trim('SP0724_FA (1)'), ' [(]\d+[)]$', 'x') as str_2
The online testing app at regex101.com matches this.  However, Hive returns the same value for str and str_2.  I would expect to see "SP0724_FAx" as the str_2 value.  Please note the space at the beginning of the regex pattern.
Any ideas?
Thank you!
Re: Regex not giving same results as other regex engines
Turned out to be pretty simple.  Hadoop (or at least Hive) prefers two backslashes like \\d rather than \d.  I ended up using this, which also requires one to four digits.
 [(]\\d{1,4}[)]$
