HUE Quick Start Wizard Stuck at Checking Current Configuration
Good Day All,
I installed CDH 5.12.0 on Windows 10 (home edition) / i3 64 bit OS with 8 GB RAM.
When I click on Quick Start, the HUE Quick Start Wizard gets stuck at Checking Current Configuration. Please see attached image.
I will appreciate if somebody can help me resolve this issue.
Thanks.
Regards,
-Shakeel
Re: HUE Quick Start Wizard Stuck at Checking Current Configuration
I was trying today, mine is stuck too. Did your issue got resolved?
if yes, Please tell me how then?
Thanks,
Smita
[ Edited ]
I've had the same experience using virtual box on OSX.
I'm also having same problem
Hello, I'm facing the same issue here. I don't know if it helps, but here is my cloudera configuration :ConfigVirtualBox.png
For people facing the same issue : have you find a solution to this problem ?
Same issue with Ubuntu 18.04 host.
Same problem with Ubuntu 18.04 host...
anyone found a solution ? having the same issue :(
was this issue resolved ? Pls revert if sorted.  :)
