Cloudera Labs
Provide feedback on Cloudera Labs
Problem of compatibility of an external orc and Claudera’s hive
Solved Go to solution
I can not solve the problem of compatibility of an external orc and Claudera’s hive.
I have cloudera express version 6.3.2 with hive version 2.1.1
In general, it’s strange, I downloaded the latest version of claudera, and there is old hive 2.1.1 there
Case:
- Externally I create some orc (I tried to create it in the local spark and in the same cloudera through map reducer job - the same result)
- I'm trying to read this orc in my claudera even through orcfiledump
- I get
Exception in thread "main" java.lang.ArrayIndexOutOfBoundsException: 6
at org.apache.orc.OrcFile $ WriterVersion.from (OrcFile.java:145)
- I downloaded the orc-tools-1.5.5-uber.jar utility locally to my computer
- Also downloaded there the problematic orc
- Performed by java -jar orc-tools-1.5.5-uber.jar meta msout2o12.orc
- Uber jar with its own hadoop inside have read this orc ok
Structure for msout2o12.orc
File Version: 0.12 with ORC_135
Rows: 242
Compression: ZLIB
Compression size: 262144
Without any creation of tables, just a hive in the cloudera can stupidly not be able to read the orc using its own utility.
The problem begun from the fact that I created an external table and hiveql on the orc generated such error.
But here it just stupidly reduced the problem to a minimum, just hive --orafiledump can not read the orc.
How to make cloudera read normally orcs? ..
What to tighten up in my cloudera?
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Problem of compatibility of an external orc and Claudera’s hive
Contributor
2 REPLIES 2
Contributor
Thank you for reply!
I have read in official hive doc that orc format is native for hive, so I prefered use orc and rebuild my ETL from parquet to orc.
But you showed me that cloudera's hive is something other then hive in general and I am very suprised by that )
Ok, I will switch to parquet again.
By the way, if I create external table with stored as orc and run some insert from hive then all is ok and cloudera's hive created 000000_0.orc files and works with it very well.
But from external world (streamsets, spark), yes, hive does not accept orc.
I have some problems with hive+parquet processing too (this is a reason I switched to orc format), but it is another question and another story
Thank you again! I spent a lot of time trying to understand what is wrong with hive and orc.
So classic is classic, I will use parquet at this time.
Don't have an account?
