Accepted Solution
Can't switch Hive engine to Spark
Hi guys,
So I was trying to switch Hive engine from MR to Spark. I follow the like here . But I didn't see any Spark service name in the Spark On YARN Service under Configuration tab. Notice that there's already a gateway on running HiveServer2. Another thing worth to notice is that Spark 2 is manually installed. Here are some snapshots.
Screen Shot 2017-01-25 at 1.46.43 PM.pngScreen Shot 2017-01-25 at 1.53.34 PM.png
Any input would be helpful. Thanks!
Cloudera Employee
Re: Can't switch Hive engine to Spark
The screenshots is not available to me. Do you only have Spark2 service on Spark side?
Sorry could you be more specific? Not sure I understand
Cloudera Employee
I am asking if your Spark service is Spark2 or not? Cloudera Manager is not supporting directly configuring Hive to depend on Spark2 yet. So you might want to try using 'Spark1' and see.
Our community is getting a little larger. And a lot better.
Learn More about the Cloudera and Hortonworks community merger planned for late July and early August.
