Accepted Solution
How do I resolve clock offset issue?
I get following health issue.
The host's NTP service did not respond to a request for the clock offset.
How do I resolve it?
Thanks,
Kewal
Re: How do I resolve clock offset issue?
I just saw this after an office move. The servers were offline for a while.
This is what I did for our CentOS Linux servers (similar, but not the same, steps would work for Ubuntu/Debian):
* verified/updated the /etc/ntp.conf file to be the same across the cluster
* stopped the ntp daemon: /etc/init.d/ntpd stop
* connected to the ntp server named in the ntp.conf file: ntpupdate <ntp_server>
* started the ntp daemon: /etc/init.d/ntpd start
* added ntpd to the startup manager: chkconfig add ntpd
* set ntpd to start in default reunlevels: chkconfig ntpd on
This cleared the offset issue. If this doesn't do it for you, you might also have to look into drift, or dig deeper into the time synchronization.
Thanks a lot for you detailed answer.
I deleted the cluster and rebuilt it from scratch. Now, it is working fine.(Fingers crossed)
But, It seems, your procedure would definitely solve the problem.
Thanks for your detailed answer. it helped me!
I had to repeat the step 4 and 5 twice; but it fixed my issue. I'm keeping the fingers crossed now! :)
[ Edited ]
Many thanks. I followed these  steps and it fixed my clock offset issue.
Expert Contributor
i got the next:
$sudo service ntp stop
* Stopping NTP server ntpd [ OK ]
root@cluster-01:~# sudo ntpdate ntp.ubuntu.com
11 Jun 06:47:14 ntpdate[29757]: no server suitable for synchronization found
i try to do it with the with NTP .. instead NTPD
Expert Contributor
Hi anton_85
Try this article, it explains time zones and settings which is very well explained.
http://www.linuxsecrets.com/easyblog/2015/01/30/1374-fixing-date-and-setting-time-and-zone-on-rhel-6...
Hi nauseous,
apprently, the problem is at my firewall, where I can't ping my gateway neither other sites out of my network.
so that's way i can't see it.
Contributor
Hi,
If firewall is the problem you can ask network admin to open add chains to that specific URL . or the other way you can set up your own NTP server within that network itself.
Thanks,
Sathish
Thanks,
Sathish (Satz)
