OOZIE WORK FLOW FAILING
Hello,
We have upgraded CDH from 5.7 to 5.11 and now we are getting Delegation Token kerberose error when running a spark job through oozie. and  below properties has already been set to false
spark.yarn.security.tokens.hive.enabled</name>
hive.server2.enable.doAs
This happens only when running from oozie. Please help
2017-07-20 15:13:46,847 [main] ERROR hive.ql.metadata.Hive  - MetaException(message:Delegation Token can be issued only with kerberos authentication. Current AuthenticationMethod: TOKEN)
	at org.apache.hadoop.hive.metastore.api.ThriftHiveMetastore$get_delegation_token_result$get_delegation_token_resultStandardScheme.read(ThriftHiveMetastore.java)
	at org.apache.hadoop.hive.metastore.api.ThriftHiveMetastore$get_delegation_token_result.read(ThriftHiveMetastore.java)
	at org.apache.thrift.TServiceClient.receiveBase(TServiceClient.java:86)
	at org.apache.hadoop.hive.metastore.api.ThriftHiveMetastore$Client.recv_get_delegation_token(ThriftHiveMetastore.java:3815)
	at org.apache.hadoop.hive.metastore.api.ThriftHiveMetastore$Client.get_delegation_token(ThriftHiveMetastore.java:3801)
	at org.apache.hadoop.hive.metastore.HiveMetaStoreClient.getDelegationToken(HiveMetaStoreClient.java:1882)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.apache.hadoop.hive.metastore.RetryingMetaStoreClient.invoke(RetryingMetaStoreClient.java:105)
	at com.sun.proxy.$Proxy31.getDelegationToken(Unknown Source)
	at org.apache.hadoop.hive.metastore.HiveMetaStoreClient$SynchronizedHandler.invoke(HiveMetaStoreClient.java:2067)
	at org.apache.hadoop.hive.ql.metadata.Hive.getDelegationToken(Hive.java:3439)
	at org.apache.spark.deploy.yarn.YarnSparkHadoopUtil$$anonfun$obtainTokenForHiveMetastoreInner$4.apply(YarnSparkHadoopUtil.scala:208)
	at org.apache.spark.deploy.yarn.YarnSparkHadoopUtil$$anonfun$obtainTokenForHiveMetastoreInner$4.apply(YarnSparkHadoopUtil.scala:206)
	at org.apache.spark.deploy.yarn.YarnSparkHadoopUtil$$anon$1.run(YarnSparkHadoopUtil.scala:237)
	at javax.security.auth.Subject.doAs(Subject.java:415)
	at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1920)
	at org.apache.spark.deploy.yarn.YarnSparkHadoopUtil.doAsRealUser(YarnSparkHadoopUtil.scala:236)
	at org.apache.spark.deploy.yarn.YarnSparkHadoopUtil.obtainTokenForHiveMetastoreInner(YarnSparkHadoopUtil.scala:206)
	at org.apache.spark.deploy.yarn.YarnSparkHadoopUtil.obtainTokenForHiveMetastore(YarnSparkHadoopUtil.scala:161)
	at org.apache.spark.deploy.yarn.Client$.org$apache$spark$deploy$yarn$Client$$obtainTokenForHiveMetastore(Client.scala:1367)
	at org.apache.spark.deploy.yarn.Client.prepareLocalResources(Client.scala:351)
	at org.apache.spark.deploy.yarn.Client.createContainerLaunchContext(Client.scala:724)
	at org.apache.spark.deploy.yarn.Client.submitApplication(Client.scala:143)
	at org.apache.spark.deploy.yarn.Client.run(Client.scala:1022)
	at org.apache.spark.deploy.yarn.Client$.main(Client.scala:1082)
