Problem configuring SSL secure connection in Kafka using Cloudera Manager 5.13.0 and S.O Centos 6
Hi  People
I am trying to make a secure communication between a producer and a consumer in Kafka (1.0.1)
by enabling the SSL protocol, however after the generation of the certificates and configure
the server.properties file through the Cloudera Manager(Version 5.13.0 and S.O Centos 6), when
I made the connection test using the openssl s_client -debug -connect localhost:9093 -tls1
I have the following error, someone can help me
CONNECTED(00000003)
write to 0x1a9e670 [0x1ae9713] (155 bytes => 155 (0x9B))
0000 - 16 03 01 00 96 01 00 00-92 03 01 5b c6 7c 3d 62   ...........[.|=b
0010 - 53 b1 25 75 34 88 fd 60-7a 41 93 51 68 3a 63 d5   S.%u4..`zA.Qh:c.
0020 - 57 14 37 6e 78 bd bc 38-e4 d7 ef 00 00 4c c0 14   W.7nx..8.....L..
0030 - c0 0a 00 39 00 38 00 88-00 87 c0 0f c0 05 00 35   ...9.8.........5
0040 - 00 84 c0 13 c0 09 00 33-00 32 c0 12 c0 08 00 9a   .......3.2......
0050 - 00 99 00 45 00 44 00 16-00 13 c0 0e c0 04 c0 0d   ...E.D..........
0060 - c0 03 00 2f 00 96 00 41-00 0a 00 07 c0 11 c0 07   .../...A........
0070 - c0 0c c0 02 00 05 00 04-00 ff 01 00 00 1d 00 0b   ................
0080 - 00 04 03 00 01 02 00 0a-00 08 00 06 00 19 00 18   ................
0090 - 00 17 00 23 00 00 00 0f-00 01 01                  ...#.......
read from 0x1a9e670 [0x1ae51c3] (5 bytes => 5 (0x5))
0005 - <SPACES/NULS>
write to 0x1a9e670 [0x1aeebe0] (7 bytes => 7 (0x7))
0000 - 15 03 01 00 02 02 46                              ......F
140660245464904:error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number:s3_pkt.c:339:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 5 bytes and written 7 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol  : TLSv1
Cipher    : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg   : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1539734589
Timeout   : 7200 (sec)
Verify return code: 0 (ok)
Additionally my logs says
2018-10-11 12:38:16,510 WARN org.apache.kafka.common.network.SslTransportLayer: Failed to send SSL Close message
java.io.IOException: Connection reset by peer
        at sun.nio.ch.FileDispatcherImpl.write0(Native Method)
        at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47)
        at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)
        at sun.nio.ch.IOUtil.write(IOUtil.java:65)
        at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:487)
        at org.apache.kafka.common.network.SslTransportLayer.flush(SslTransportLayer.java:212)
        at org.apache.kafka.common.network.SslTransportLayer.close(SslTransportLayer.java:175)
        at org.apache.kafka.common.utils.Utils.closeAll(Utils.java:703)
        at org.apache.kafka.common.network.KafkaChannel.close(KafkaChannel.java:61)
        at org.apache.kafka.common.network.Selector.doClose(Selector.java:739)
        at org.apache.kafka.common.network.Selector.close(Selector.java:727)
        at org.apache.kafka.common.network.Selector.pollSelectionKeys(Selector.java:520)
        at org.apache.kafka.common.network.Selector.poll(Selector.java:412)
        at kafka.network.Processor.poll(SocketServer.scala:551)
        at kafka.network.Processor.run(SocketServer.scala:468)
        at java.lang.Thread.run(Thread.java:745)
PROCEDURE TO MAKE THE CERTIFICATES
CERTIFICATION AUTHORITY
openssl req -new -newkey rsa:4096 -days 365 -x509 -subj "/CN=Kafka-Security-CA" -keyout ca-key -out ca-cert -nodes
CREATING SERVER CERTIFICATE
Using my hostname (quickstart.cloudera)
keytool -genkey -keystore kafka.server.keystore.jks -validity 365 -storepass $SRVPASS -keypass $SRVPASS  -dname "CN=quickstart.cloudera" -storetype pkcs12
CREATE A CERTIFICATION REQUEST FILE
keytool -keystore kafka.server.keystore.jks -certreq -file cert-file -storepass $SRVPASS -keypass $SRVPASS
openssl x509 -req -CA ca-cert -CAkey ca-key -in cert-file -out cert-signed -days 365 -CAcreateserial -passin pass:$SRVPASS
CHECK CERTIFICATES
keytool -printcert -v -file cert-signed
keytool -list -v -keystore kafka.server.keystore.jks
keytool -keystore kafka.server.truststore.jks -alias CARoot -import -file ca-cert -storepass $SRVPASS -keypass $SRVPASS -noprompt
IMPORT CA AND THE SIGNED SERVER CERTIFICATE INTO KEYSTORE
keytool -keystore kafka.server.keystore.jks -alias CARoot -import -file ca-cert -storepass $SRVPASS -keypass $SRVPASS -noprompt
keytool -keystore kafka.server.keystore.jks -import -file cert-signed -storepass $SRVPASS -keypass $SRVPASS -noprompt
keytool -keystore kafka.client.keystore.jks -alias localhost -certreq -file cert-file
openssl x509 -req -CA ca-cert -CAkey ca-key -in cert-file -out cert-signed -days $VALIDITY -CAcreateserial -passin pass:$PASSWORD
keytool -keystore kafka.client.keystore.jks -alias CARoot -import -file ca-cert
keytool -keystore kafka.client.keystore.jks -alias localhost -import -file cert-signed
KAFKA SERVER PROPERTIES
listeners=PLAINTEXT://0.0.0.0:9092,SSL://0.0.0.0:9093
ssl.keystore.location=/var/private/ssl-new-5/kafka.server.keystore.jks
ssl.keystore.password=XXXXXX
ssl.key.password=XXXXXX
ssl.truststore.location=/var/private/ssl-new-5/kafka.server.truststore.jks
ssl.truststore.password=XXXXXXX
offsets.topic.replication.factor=1
transaction.state.log.replication.factor=1
transaction.state.log.min.isr=1
I appreciate any help to solve this problem
