Code Repositories
Find and share code repositories
Check out our newest addition to the community, the Cloudera Innovation Accelerator group hub.
Repo Description
  • Deploy & configure NiFi templates with a touch of a button (or, rather, a single command)
  • Specify a URI to fetch a Template from - meaning it can be a local file system, remote HTTP URL, or any other exotic location for which you have a URLHandler installed
  • Describe NiFi state and configuration properties for things you want tweaked in a template. YAML format came out to be the cleanest and most usable option (YAML is a subset of JSON)
  • (Recommended) Tell NiFi what things are in your way and have them undeployed as part of the process. Good idea if one wants a deployment to be idempotent.
Repo Info
Github Repo URL https://github.com/aperepel/nifi-api-deploy
Github account name aperepel
Repo name nifi-api-deploy
Comments
Hi Andrew,
Silly question, however as the nifi-api-deploy been updated to use the latest NiFi API, or still pointing at the old?
Cheers
Don't have an account?
Version history
Last update:
‎03-14-2016 01:56 PM
Updated by:
Contributors
Top Kudoed Authors
