Problem about Configuring Flume as Kafka Consumer
My Configuration is
Cloudera Manager 5.12.1
Flume 1.7.0
Kakfa 2.2.0-1.2.2.0.p0.68
I created topic "test" in kafka, and would like to configure flume to act as consumer to fetch data from this topic and save it to HDFS.
My flume configuration is
tier1.sources = source1
tier1.channels = channel1
tier1.sinks = sink1
tier1.sources.source1.type = org.apache.flume.source.kafka.KafkaSource
tier1.sources.source1.zookeeperConnect = bda03:2182, bda04:2182,bda05:2182
tier1.sources.source1.topic = test
tier1.sources.source1.groupId = flume
tier1.sources.source1.channels = channel1
tier1.sources.source1.interceptors = i1
tier1.sources.source1.interceptors.i1.type = timestamp
tier1.sources.source1.kafka.consumer.timeout.ms = 100
tier1.channels.channel1.type = memory
tier1.channels.channel1.capacity = 10000
tier1.channels.channel1.transactionCapacity = 1000
tier1.sinks.sink1.type = hdfs
tier1.sinks.sink1.hdfs.path = /user/flume/tmp/
tier1.sinks.sink1.hdfs.rollInterval = 5
tier1.sinks.sink1.hdfs.rollSize = 0
tier1.sinks.sink1.hdfs.rollCount = 0
tier1.sinks.sink1.hdfs.fileType = DataStream
tier1.sinks.sink1.channel = channel1
The configuration was just copied from https://www.cloudera.com/documentation/kafka/latest/topics/kafka_flume.html
After starting the flume agent, there was no error message in flume and kafka log file.
I tried to put some records to topics:
$ kafka-console-producer --broker-list bda03:9092,bda04:9092,bda05:9092 --topic test
Hello
This is new message
However, there was nothing put into HDFS.
Then, I tried to retreive message from topic "test" via command line (with consumer group flume)
$ kafka-console-consumer --zookeeper bda03:2182,bda04:2182,bda05:2182 --topic test --consumer-property group.id=flume
The output was:
Hello
This is new message
If the flume agent could fetch message from the topic, then the output of the above command should be empty.
The result indicated that the flume agent could not get any data from Kafka.
Can anyone help?
Thanks!
Re: Problem about Configuring Flume as Kafka Consumer
The flume agent log file was:
2017-10-18 17:01:49,742 INFO org.apache.flume.node.PollingPropertiesFileConfigurationProvider: Configuration provider starting
2017-10-18 17:01:49,760 INFO org.apache.flume.node.PollingPropertiesFileConfigurationProvider: Reloading configuration file:/run/cloudera-scm-agent/process/2727-flume-AGENT/flume.conf
2017-10-18 17:01:49,765 INFO org.apache.flume.conf.FlumeConfiguration: Processing:sink1
2017-10-18 17:01:49,766 INFO org.apache.flume.conf.FlumeConfiguration: Processing:sink1
2017-10-18 17:01:49,766 INFO org.apache.flume.conf.FlumeConfiguration: Added sinks: sink1 Agent: tier1
2017-10-18 17:01:49,783 INFO org.apache.flume.conf.FlumeConfiguration: Post-validation flume configuration contains configuration for agents: [tier1]
2017-10-18 17:01:49,783 INFO org.apache.flume.node.AbstractConfigurationProvider: Creating channels
2017-10-18 17:01:49,790 INFO org.apache.flume.channel.DefaultChannelFactory: Creating instance of channel channel1 type memory
2017-10-18 17:01:49,798 INFO org.apache.flume.node.AbstractConfigurationProvider: Created channel channel1
2017-10-18 17:01:49,799 INFO org.apache.flume.source.DefaultSourceFactory: Creating instance of source source1, type org.apache.flume.source.kafka.KafkaSource
2017-10-18 17:01:49,835 INFO org.apache.flume.sink.DefaultSinkFactory: Creating instance of sink: sink1, type: hdfs
2017-10-18 17:01:49,847 INFO org.apache.flume.node.AbstractConfigurationProvider: Channel channel1 connected to [source1, sink1]
2017-10-18 17:01:49,854 INFO org.apache.flume.node.Application: Starting new configuration:{ sourceRunners:{source1=PollableSourceRunner: { source:org.apache.flume.source.kafka.KafkaSource{name:source1,state:IDLE} counterGroup:{ name:null counters:{} } }} sinkRunners:{sink1=SinkRunner: { policy:org.apache.flume.sink.DefaultSinkProcessor@705cdf05 counterGroup:{ name:null counters:{} } }} channels:{channel1=org.apache.flume.channel.MemoryChannel{name: channel1}} }
2017-10-18 17:01:49,855 INFO org.apache.flume.node.Application: Starting Channel channel1
2017-10-18 17:01:49,908 INFO org.apache.flume.instrumentation.MonitoredCounterGroup: Monitored counter group for type: CHANNEL, name: channel1: Successfully registered new MBean.
2017-10-18 17:01:49,909 INFO org.apache.flume.instrumentation.MonitoredCounterGroup: Component type: CHANNEL, name: channel1 started
2017-10-18 17:01:49,909 INFO org.apache.flume.node.Application: Starting Sink sink1
2017-10-18 17:01:49,910 INFO org.apache.flume.instrumentation.MonitoredCounterGroup: Monitored counter group for type: SINK, name: sink1: Successfully registered new MBean.
2017-10-18 17:01:49,911 INFO org.apache.flume.instrumentation.MonitoredCounterGroup: Component type: SINK, name: sink1 started
2017-10-18 17:01:49,913 INFO org.apache.flume.node.Application: Starting Source source1
2017-10-18 17:01:49,914 INFO org.apache.flume.source.kafka.KafkaSource: Starting org.apache.flume.source.kafka.KafkaSource{name:source1,state:IDLE}...
2017-10-18 17:01:49,941 INFO org.apache.kafka.clients.consumer.ConsumerConfig: ConsumerConfig values:
metric.reporters = []
metadata.max.age.ms = 300000
value.deserializer = class org.apache.kafka.common.serialization.ByteArrayDeserializer
group.id = abcd
partition.assignment.strategy = [org.apache.kafka.clients.consumer.RangeAssignor]
reconnect.backoff.ms = 50
sasl.kerberos.ticket.renew.window.factor = 0.8
max.partition.fetch.bytes = 1048576
bootstrap.servers = [bda03.aslsdc.local:9092, bda04.aslsdc.local:9092, bda05.aslsdc.local:9092]
retry.backoff.ms = 100
sasl.kerberos.kinit.cmd = /usr/bin/kinit
sasl.kerberos.service.name = null
sasl.kerberos.ticket.renew.jitter = 0.05
ssl.keystore.type = JKS
ssl.trustmanager.algorithm = PKIX
enable.auto.commit = false
ssl.key.password = null
fetch.max.wait.ms = 500
sasl.kerberos.min.time.before.relogin = 60000
connections.max.idle.ms = 540000
ssl.truststore.password = null
session.timeout.ms = 30000
metrics.num.samples = 2
client.id =
ssl.endpoint.identification.algorithm = null
key.deserializer = class org.apache.kafka.common.serialization.StringDeserializer
ssl.protocol = TLS
check.crcs = true
request.timeout.ms = 40000
ssl.provider = null
ssl.enabled.protocols = [TLSv1.2, TLSv1.1, TLSv1]
ssl.keystore.location = null
heartbeat.interval.ms = 3000
auto.commit.interval.ms = 5000
receive.buffer.bytes = 65536
ssl.cipher.suites = null
ssl.truststore.type = JKS
security.protocol = PLAINTEXT
ssl.truststore.location = null
ssl.keystore.password = null
ssl.keymanager.algorithm = SunX509
metrics.sample.window.ms = 30000
fetch.min.bytes = 1
send.buffer.bytes = 131072
auto.offset.reset = latest
2017-10-18 17:01:49,952 INFO org.mortbay.log: Logging to org.slf4j.impl.Log4jLoggerAdapter(org.mortbay.log) via org.mortbay.log.Slf4jLog
2017-10-18 17:01:49,994 INFO org.mortbay.log: jetty-6.1.26.cloudera.4
2017-10-18 17:01:50,016 INFO org.mortbay.log: Started SelectChannelConnector@0.0.0.0:41414
2017-10-18 17:01:50,066 INFO org.apache.kafka.common.utils.AppInfoParser: Kafka version : 0.9.0-kafka-2.0.2
2017-10-18 17:01:50,066 INFO org.apache.kafka.common.utils.AppInfoParser: Kafka commitId : unknown
Did you find any solution? I am facing exact issue
Expert Contributor
tier1.sources.source1.zookeeperConnect is deprecated,
use tier1.sources.kafkasource1.kafka.bootstrap.servers = bda03:9092, bda04:9092,bda05:9092.
Em Jay
Cloudera Employee
As Manikumar noted above, the old flume agent configuration has been deprecated, you can refer to the flume kafka source here:
http://flume.apache.org/FlumeUserGuide.html
Also, you can confirm with the consumerGroupCommand that the flume agents are in an acive consumer group:
kafka-run-class kafka.admin.ConsumerGroupCommand --bootstrap-server ${HOSTNAME}:9092 --describe --group flume --new-consumer
-pd
MMG
hi All,
I have been trying to ingest data from kafka source to flume. I am using cloudera quickstart vm 5.13.
My flume config file is this :
 agent1.sources = kafka-source
 agent1.channels = memory-channel
 agent1.sinks = hdfs-sink
 agent1.sources.kafka-source.type = org.apache.flume.source.kafka.KafkaSource
 agent1.sources.kafka-source.kafka.bootstrap.servers = quickstart.cloudera:9092
 agent1.sources.kafka-source.kafka.topics = Airports
 agent1.sources.kafka-source.kafka.consumer.groupId = flume
 agent1.sources.kafka-source-kafka.batchSize = 1
 agent1.sources.kafka-source.channels = memory-channel
 agent1.sources.kafka-source.interceptors = i1
 agent1.sources.kafka-source.interceptors.i1.type = timestamp
 agent1.sources.kafka-source.interceptors.i1.preserveExisting = false
 agent1.sources.kafka-source.interceptors.i1.hostHeader = key
 agent1.sources.kafka-source.kafka.consumer.timeout.ms = 100
 agent1.sources.kafka-source.kafka.enable.auto.commit = true
 agent1.channels.memory-channel.type = memory
 agent1.channels.memory-channel.capacity = 10000
 agent1.channels.memory-channel.transactionCapacity = 1000
 agent1.sinks.hdfs-sink.type = hdfs
 agent1.sinks.hdfs-sink.hdfs.path = hdfs://quickstart.cloudera:8020/tmp/kafka/
 agent1.sinks.hdfs-sink.hdfs.rollInterval = 5
 agent1.sinks.hdfs-sink.hdfs.rollSize = 1
 agent1.sinks.hdfs-sink.hdfs.rollCount = 0
 agent1.sinks.hdfs-sink.hdfs.fileType = DataStream
 agent1.sinks.hdfs-sink.channel = memory-channel
The flume command I ran is :
./bin/flume-ng agent --conf conf -conf-file conf/flumekafka.conf --name agent1 -Dflume.root.logger=INFO,console
in /usr/lib/flume-ng location.
The kafka producer command and log is as below:
[cloudera@quickstart Desktop]$ /usr/bin/kafka-console-producer --broker-list quickstart.cloudera:9092 --topic Airports
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/opt/cloudera/parcels/KAFKA-3.0.0-1.3.0.0.p0.40/lib/kafka/libs/slf4j-log4j12-1.7.25.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/opt/cloudera/parcels/KAFKA-3.0.0-1.3.0.0.p0.40/lib/kafka/libs/slf4j-log4j12-1.7.5.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [org.slf4j.impl.Log4jLoggerFactory]
18/03/16 02:07:09 INFO producer.ProducerConfig: ProducerConfig values:
    acks = 1
    batch.size = 16384
    bootstrap.servers = [quickstart.cloudera:9092]
    buffer.memory = 33554432
    client.id = console-producer
    compression.type = none
    enable.idempotence = false
    interceptor.classes = null
    key.serializer = class org.apache.kafka.common.serialization.ByteArraySerializer
    linger.ms = 1000
    max.block.ms = 60000
    max.in.flight.requests.per.connection = 5
    max.request.size = 1048576
    metrics.recording.level = INFO
    partitioner.class = class org.apache.kafka.clients.producer.internals.DefaultPartitioner
    receive.buffer.bytes = 32768
    reconnect.backoff.max.ms = 1000
    request.timeout.ms = 1500
    retries = 3
    sasl.jaas.config = null
    sasl.mechanism = GSSAPI
    send.buffer.bytes = 102400
    ssl.protocol = TLS
    ssl.provider = null
    ssl.secure.random.implementation = null
    transaction.timeout.ms = 60000
    transactional.id = null
    value.serializer = class org.apache.kafka.common.serialization.ByteArraySerializer
18/03/16 02:07:10 INFO utils.AppInfoParser: Kafka version : 0.11.0-kafka-3.0.0
18/03/16 02:07:10 INFO utils.AppInfoParser: Kafka commitId : unknown
>hi
>this is a new message
The flume command and log is as follows :
[cloudera@quickstart flume-ng]$ ./bin/flume-ng agent --conf conf -conf-file conf/flumekafka.conf --name agent1 -Dflume.root.logger=INFO,console
Info: Including Hadoop libraries found via (/usr/bin/hadoop) for HDFS access
Info: Including HBASE libraries found via (/usr/bin/hbase) for HBASE access
Info: Including Hive libraries found via () for Hive access
+ exec /usr/java/jdk1.7.0_67-cloudera/bin/java -Xmx20m -Dflume.root.logger=INFO,console -cp '/usr/lib/flume-ng/conf:/usr/lib/flume-ng/lib/*:/etc/hadoop/conf:/usr/lib/hadoop/lib/*:/usr/lib/hadoop/.//*:/usr/lib/hadoop-hdfs/./:/usr/lib/hadoop-hdfs/lib/*:/usr/lib/hadoop-hdfs/.//*:/usr/lib/hadoop-yarn/lib/*:/usr/lib/hadoop-yarn/.//*:/opt/cloudera/parcels/CDH/lib/hadoop-mapreduce/lib/*:/opt/cloudera/parcels/CDH/lib/hadoop-mapreduce/.//*:/usr/lib/hbase/bin/../conf:/usr/java/jdk1.7.0_67-cloudera/lib/tools.jar:/usr/lib/hbase/bin/..:/usr/lib/hbase/bin/../lib/activation-1.1.jar:/usr/lib/hbase/bin/../lib/apacheds-i18n-2.0.0-M15.jar:/usr/lib/hbase/bin/../lib/apacheds-kerberos-codec-2.0.0-M15.jar:/usr/lib/hbase/bin/../lib/api-asn1-api-1.0.0-M20.jar:/usr/lib/hbase/bin/../lib/api-util-1.0.0-M20.jar:/usr/lib/hbase/bin/../lib/asm-3.2.jar:/usr/lib/hbase/bin/../lib/avro.jar:/usr/lib/hbase/bin/../lib/aws-java-sdk-bundle-1.11.134.jar:/usr/lib/hbase/bin/../lib/commons-beanutils-1.9.2.jar:/usr/lib/hbase/bin/../lib/commons-beanutils-core-1.8.0.jar:/usr/lib/hbase/bin/../lib/commons-cli-1.2.jar:/usr/lib/hbase/bin/../lib/commons-codec-1.9.jar:/usr/lib/hbase/bin/../lib/commons-collections-3.2.2.jar:/usr/lib/hbase/bin/../lib/commons-compress-1.4.1.jar:/usr/lib/hbase/bin/../lib/commons-configuration-1.6.jar:/usr/lib/hbase/bin/../lib/commons-daemon-1.0.13.jar:/usr/lib/hbase/bin/../lib/commons-digester-1.8.jar:/usr/lib/hbase/bin/../lib/commons-el-1.0.jar:/usr/lib/hbase/bin/../lib/commons-httpclient-3.1.jar:/usr/lib/hbase/bin/../lib/commons-io-2.4.jar:/usr/lib/hbase/bin/../lib/commons-lang-2.6.jar:/usr/lib/hbase/bin/../lib/commons-logging-1.2.jar:/usr/lib/hbase/bin/../lib/commons-math-2.1.jar:/usr/lib/hbase/bin/../lib/commons-math3-3.1.1.jar:/usr/lib/hbase/bin/../lib/commons-net-3.1.jar:/usr/lib/hbase/bin/../lib/core-3.1.1.jar:/usr/lib/hbase/bin/../lib/curator-client-2.7.1.jar:/usr/lib/hbase/bin/../lib/curator-framework-2.7.1.jar:/usr/lib/hbase/bin/../lib/curator-recipes-2.7.1.jar:/usr/lib/hbase/bin/../lib/disruptor-3.3.0.jar:/usr/lib/hbase/bin/../lib/findbugs-annotations-1.3.9-1.jar:/usr/lib/hbase/bin/../lib/gson-2.2.4.jar:/usr/lib/hbase/bin/../lib/guava-12.0.1.jar:/usr/lib/hbase/bin/../lib/hamcrest-core-1.3.jar:/usr/lib/hbase/bin/../lib/hbase-annotations-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-annotations-1.2.0-cdh5.13.0-tests.jar:/usr/lib/hbase/bin/../lib/hbase-client-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-common-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-common-1.2.0-cdh5.13.0-tests.jar:/usr/lib/hbase/bin/../lib/hbase-examples-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-external-blockcache-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-hadoop2-compat-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-hadoop2-compat-1.2.0-cdh5.13.0-tests.jar:/usr/lib/hbase/bin/../lib/hbase-hadoop-compat-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-hadoop-compat-1.2.0-cdh5.13.0-tests.jar:/usr/lib/hbase/bin/../lib/hbase-it-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-it-1.2.0-cdh5.13.0-tests.jar:/usr/lib/hbase/bin/../lib/hbase-prefix-tree-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-procedure-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-protocol-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-resource-bundle-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-rest-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-rsgroup-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-rsgroup-1.2.0-cdh5.13.0-tests.jar:/usr/lib/hbase/bin/../lib/hbase-server-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-server-1.2.0-cdh5.13.0-tests.jar:/usr/lib/hbase/bin/../lib/hbase-shell-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-spark-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/hbase-thrift-1.2.0-cdh5.13.0.jar:/usr/lib/hbase/bin/../lib/high-scale-lib-1.1.1.jar:/usr/lib/hbase/bin/../lib/hsqldb-1.8.0.10.jar:/usr/lib/hbase/bin/../lib/htrace-core-3.2.0-incubating.jar:/usr/lib/hbase/bin/../lib/htrace-core4-4.0.1-incubating.jar:/usr/lib/hbase/bin/../lib/htrace-core.jar:/usr/lib/hbase/bin/../lib/httpclient-4.2.5.jar:/usr/lib/hbase/bin/../lib/httpcore-4.2.5.jar:/usr/lib/hbase/bin/../lib/jackson-annotations-2.2.3.jar:/usr/lib/hbase/bin/../lib/jackson-core-2.2.3.jar:/usr/lib/hbase/bin/../lib/jackson-core-asl-1.8.8.jar:/usr/lib/hbase/bin/../lib/jackson-databind-2.2.3.jar:/usr/lib/hbase/bin/../lib/jackson-jaxrs-1.8.8.jar:/usr/lib/hbase/bin/../lib/jackson-mapper-asl-1.8.8.jar:/usr/lib/hbase/bin/../lib/jackson-xc-1.8.8.jar:/usr/lib/hbase/bin/../lib/jamon-runtime-2.4.1.jar:/usr/lib/hbase/bin/../lib/jasper-compiler-5.5.23.jar:/usr/lib/hbase/bin/../lib/jasper-runtime-5.5.23.jar:/usr/lib/hbase/bin/../lib/java-xmlbuilder-0.4.jar:/usr/lib/hbase/bin/../lib/jaxb-api-2.1.jar:/usr/lib/hbase/bin/../lib/jaxb-impl-2.2.3-1.jar:/usr/lib/hbase/bin/../lib/jcodings-1.0.8.jar:/usr/lib/hbase/bin/../lib/jersey-client-1.9.jar:/usr/lib/hbase/bin/../lib/jersey-core-1.9.jar:/usr/lib/hbase/bin/../lib/jersey-json-1.9.jar:/usr/lib/hbase/bin/../lib/jersey-server-1.9.jar:/usr/lib/hbase/bin/../lib/jets3t-0.9.0.jar:/usr/lib/hbase/bin/../lib/jettison-1.3.3.jar:/usr/lib/hbase/bin/../lib/jetty-6.1.26.cloudera.4.jar:/usr/lib/hbase/bin/../lib/jetty-sslengine-6.1.26.cloudera.4.jar:/usr/lib/hbase/bin/../lib/jetty-util-6.1.26.cloudera.4.jar:/usr/lib/hbase/bin/../lib/joni-2.1.2.jar:/usr/lib/hbase/bin/../lib/jruby-cloudera-1.0.0.jar:/usr/lib/hbase/bin/../lib/jsch-0.1.42.jar:/usr/lib/hbase/bin/../lib/jsp-2.1-6.1.14.jar:/usr/lib/hbase/bin/../lib/jsp-api-2.1-6.1.14.jar:/usr/lib/hbase/bin/../lib/jsp-api-2.1.jar:/usr/lib/hbase/bin/../lib/junit-4.12.jar:/usr/lib/hbase/bin/../lib/leveldbjni-all-1.8.jar:/usr/lib/hbase/bin/../lib/libthrift-0.9.3.jar:/usr/lib/hbase/bin/../lib/log4j-1.2.17.jar:/usr/lib/hbase/bin/../lib/metrics-core-2.2.0.jar:/usr/lib/hbase/bin/../lib/netty-all-4.0.23.Final.jar:/usr/lib/hbase/bin/../lib/paranamer-2.3.jar:/usr/lib/hbase/bin/../lib/protobuf-java-2.5.0.jar:/usr/lib/hbase/bin/../lib/servlet-api-2.5-6.1.14.jar:/usr/lib/hbase/bin/../lib/servlet-api-2.5.jar:/usr/lib/hbase/bin/../lib/slf4j-api-1.7.5.jar:/usr/lib/hbase/bin/../lib/slf4j-log4j12.jar:/usr/lib/hbase/bin/../lib/snappy-java-1.0.4.1.jar:/usr/lib/hbase/bin/../lib/spymemcached-2.11.6.jar:/usr/lib/hbase/bin/../lib/xmlenc-0.52.jar:/usr/lib/hbase/bin/../lib/xz-1.0.jar:/usr/lib/hbase/bin/../lib/zookeeper.jar:/etc/hadoop/conf:/usr/lib/hadoop/lib/*:/usr/lib/hadoop/.//*:/usr/lib/hadoop-hdfs/./:/usr/lib/hadoop-hdfs/lib/*:/usr/lib/hadoop-hdfs/.//*:/usr/lib/hadoop-yarn/lib/*:/usr/lib/hadoop-yarn/.//*:/opt/cloudera/parcels/CDH/lib/hadoop-mapreduce/lib/*:/opt/cloudera/parcels/CDH/lib/hadoop-mapreduce/.//*:/etc/hadoop/conf/usr/lib/hadoop/*:/usr/lib/hadoop/lib/*:/usr/lib/zookeeper/*:/usr/lib/zookeeper/lib/*::/conf:/lib/*:/usr/lib/flume-ng/../search/lib/antlr-2.7.7.jar:/usr/lib/flume-ng/../search/lib/antlr-runtime-3.4.jar:/usr/lib/flume-ng/../search/lib/apacheds-kerberos-codec-2.0.0-M15.jar:/usr/lib/flume-ng/../search/lib/apache-mime4j-core-0.7.2.jar:/usr/lib/flume-ng/../search/lib/apache-mime4j-dom-0.7.2.jar:/usr/lib/flume-ng/../search/lib/api-asn1-api-1.0.0-M20.jar:/usr/lib/flume-ng/../search/lib/api-util-1.0.0-M20.jar:/usr/lib/flume-ng/../search/lib/argparse4j-0.4.3.jar:/usr/lib/flume-ng/../search/lib/asm-3.2.jar:/usr/lib/flume-ng/../search/lib/asm-4.1.jar:/usr/lib/flume-ng/../search/lib/asm-commons-4.1.jar:/usr/lib/flume-ng/../search/lib/asm-debug-all-4.1.jar:/usr/lib/flume-ng/../search/lib/aspectjrt-1.6.5.jar:/usr/lib/flume-ng/../search/lib/avro.jar:/usr/lib/flume-ng/../search/lib/bcmail-jdk15-1.45.jar:/usr/lib/flume-ng/../search/lib/bcprov-jdk15-1.45.jar:/usr/lib/flume-ng/../search/lib/boilerpipe-1.1.0.jar:/usr/lib/flume-ng/../search/lib/commons-cli-1.2.jar:/usr/lib/flume-ng/../search/lib/commons-codec-1.4.jar:/usr/lib/flume-ng/../search/lib/commons-collections-3.2.2.jar:/usr/lib/flume-ng/../search/lib/commons-compress-1.4.1.jar:/usr/lib/flume-ng/../search/lib/commons-configuration-1.6.jar:/usr/lib/flume-ng/../search/lib/commons-el-1.0.jar:/usr/lib/flume-ng/../search/lib/commons-fileupload-1.3.2.jar:/usr/lib/flume-ng/../search/lib/commons-io-2.4.jar:/usr/lib/flume-ng/../search/lib/commons-lang-2.6.jar:/usr/lib/flume-ng/../search/lib/commons-logging-1.1.3.jar:/usr/lib/flume-ng/../search/lib/commons-math3-3.1.1.jar:/usr/lib/flume-ng/../search/lib/commons-net-3.1.jar:/usr/lib/flume-ng/../search/lib/concurrentlinkedhashmap-lru-1.2.jar:/usr/lib/flume-ng/../search/lib/config-1.0.2.jar:/usr/lib/flume-ng/../search/lib/curator-client-2.7.1.jar:/usr/lib/flume-ng/../search/lib/curator-framework-2.7.1.jar:/usr/lib/flume-ng/../search/lib/curator-recipes-2.7.1.jar:/usr/lib/flume-ng/../search/lib/dom4j-1.6.1.jar:/usr/lib/flume-ng/../search/lib/fastutil-6.3.jar:/usr/lib/flume-ng/../search/lib/fontbox-1.8.4.jar:/usr/lib/flume-ng/../search/lib/gson-2.2.4.jar:/usr/lib/flume-ng/../search/lib/guava-11.0.2.jar:/usr/lib/flume-ng/../search/lib/hadoop-annotations.jar:/usr/lib/flume-ng/../search/lib/hadoop-auth.jar:/usr/lib/flume-ng/../search/lib/hadoop-common.jar:/usr/lib/flume-ng/../search/lib/hadoop-hdfs.jar:/usr/lib/flume-ng/../search/lib/hppc-0.5.2.jar:/usr/lib/flume-ng/../search/lib/htrace-core-3.2.0-incubating.jar:/usr/lib/flume-ng/../search/lib/htrace-core4-4.0.1-incubating.jar:/usr/lib/flume-ng/../search/lib/httpclient-4.2.5.jar:/usr/lib/flume-ng/../search/lib/httpcore-4.2.5.jar:/usr/lib/flume-ng/../search/lib/httpmime-4.2.5.jar:/usr/lib/flume-ng/../search/lib/isoparser-1.0-RC-1.jar:/usr/lib/flume-ng/../search/lib/jackson-annotations-2.3.0.jar:/usr/lib/flume-ng/../search/lib/jackson-core-2.3.1.jar:/usr/lib/flume-ng/../search/lib/jackson-core-asl-1.8.8.jar:/usr/lib/flume-ng/../search/lib/jackson-databind-2.3.1.jar:/usr/lib/flume-ng/../search/lib/jackson-mapper-asl-1.8.8.jar:/usr/lib/flume-ng/../search/lib/javax.servlet-3.0.0.v201112011016.jar:/usr/lib/flume-ng/../search/lib/jcl-over-slf4j-1.7.5.jar:/usr/lib/flume-ng/../search/lib/jdom-1.0.jar:/usr/lib/flume-ng/../search/lib/jempbox-1.8.4.jar:/usr/lib/flume-ng/../search/lib/jersey-core-1.9.jar:/usr/lib/flume-ng/../search/lib/jersey-server-1.9.jar:/usr/lib/flume-ng/../search/lib/jetty-continuation-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-deploy-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-http-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-io-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-jmx-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-security-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-server-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-servlet-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-util-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-webapp-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jetty-xml-8.1.10.v20130312.jar:/usr/lib/flume-ng/../search/lib/jhighlight-1.0.jar:/usr/lib/flume-ng/../search/lib/joda-time-1.6.jar:/usr/lib/flume-ng/../search/lib/jsch-0.1.42.jar:/usr/lib/flume-ng/../search/lib/jsr305-1.3.9.jar:/usr/lib/flume-ng/../search/lib/juniversalchardet-1.0.3.jar:/usr/lib/flume-ng/../search/lib/kite-hadoop-compatibility.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-avro.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-core.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-hadoop-core.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-hadoop-parquet-avro.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-hadoop-rcfile.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-hadoop-sequencefile.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-json.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-maxmind.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-metrics-servlets.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-saxon.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-solr-cell.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-solr-core.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-tika-core.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-tika-decompress.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-twitter.jar:/usr/lib/flume-ng/../search/lib/kite-morphlines-useragent.jar:/usr/lib/flume-ng/../search/lib/leveldbjni-all-1.8.jar:/usr/lib/flume-ng/../search/lib/log4j-1.2.17.jar:/usr/lib/flume-ng/../search/lib/lucene-analyzers-common.jar:/usr/lib/flume-ng/../search/lib/lucene-analyzers-kuromoji.jar:/usr/lib/flume-ng/../search/lib/lucene-analyzers-phonetic.jar:/usr/lib/flume-ng/../search/lib/lucene-codecs.jar:/usr/lib/flume-ng/../search/lib/lucene-core.jar:/usr/lib/flume-ng/../search/lib/lucene-expressions.jar:/usr/lib/flume-ng/../search/lib/lucene-grouping.jar:/usr/lib/flume-ng/../search/lib/lucene-highlighter.jar:/usr/lib/flume-ng/../search/lib/lucene-join.jar:/usr/lib/flume-ng/../search/lib/lucene-memory.jar:/usr/lib/flume-ng/../search/lib/lucene-misc.jar:/usr/lib/flume-ng/../search/lib/lucene-queries.jar:/usr/lib/flume-ng/../search/lib/lucene-queryparser.jar:/usr/lib/flume-ng/../search/lib/lucene-spatial.jar:/usr/lib/flume-ng/../search/lib/lucene-suggest.jar:/usr/lib/flume-ng/../search/lib/maxmind-db-1.0.0.jar:/usr/lib/flume-ng/../search/lib/metadata-extractor-2.6.2.jar:/usr/lib/flume-ng/../search/lib/metrics-core-3.0.2.jar:/usr/lib/flume-ng/../search/lib/metrics-healthchecks-3.0.2.jar:/usr/lib/flume-ng/../search/lib/metrics-json-3.0.2.jar:/usr/lib/flume-ng/../search/lib/metrics-jvm-3.0.2.jar:/usr/lib/flume-ng/../search/lib/metrics-servlets-3.0.2.jar:/usr/lib/flume-ng/../search/lib/netcdf-4.2-min.jar:/usr/lib/flume-ng/../search/lib/netty-3.10.5.Final.jar:/usr/lib/flume-ng/../search/lib/netty-all-4.0.23.Final.jar:/usr/lib/flume-ng/../search/lib/noggit-0.5.jar:/usr/lib/flume-ng/../search/lib/org.restlet-2.1.4.jar:/usr/lib/flume-ng/../search/lib/org.restlet.ext.servlet-2.1.4.jar:/usr/lib/flume-ng/../search/lib/paranamer-2.3.jar:/usr/lib/flume-ng/../search/lib/parquet-avro.jar:/usr/lib/flume-ng/../search/lib/parquet-column.jar:/usr/lib/flume-ng/../search/lib/parquet-common.jar:/usr/lib/flume-ng/../search/lib/parquet-encoding.jar:/usr/lib/flume-ng/../search/lib/parquet-format.jar:/usr/lib/flume-ng/../search/lib/parquet-hadoop.jar:/usr/lib/flume-ng/../search/lib/parquet-jackson.jar:/usr/lib/flume-ng/../search/lib/pdfbox-1.8.4.jar:/usr/lib/flume-ng/../search/lib/poi-3.10-beta2.jar:/usr/lib/flume-ng/../search/lib/poi-ooxml-3.10-beta2.jar:/usr/lib/flume-ng/../search/lib/poi-ooxml-schemas-3.10.1.jar:/usr/lib/flume-ng/../search/lib/poi-scratchpad-3.10-beta2.jar:/usr/lib/flume-ng/../search/lib/protobuf-java-2.5.0.jar:/usr/lib/flume-ng/../search/lib/rome-0.9.jar:/usr/lib/flume-ng/../search/lib/Saxon-HE-9.5.1-5.jar:/usr/lib/flume-ng/../search/lib/snakeyaml-1.10.jar:/usr/lib/flume-ng/../search/lib/snappy-java-1.0.4.1.jar:/usr/lib/flume-ng/../search/lib/solr-cell.jar:/usr/lib/flume-ng/../search/lib/solr-core.jar:/usr/lib/flume-ng/../search/lib/solr-solrj.jar:/usr/lib/flume-ng/../search/lib/spatial4j-0.4.1.jar:/usr/lib/flume-ng/../search/lib/tagsoup-1.2.1.jar:/usr/lib/flume-ng/../search/lib/tika-core-1.5.jar:/usr/lib/flume-ng/../search/lib/tika-parsers-1.5.jar:/usr/lib/flume-ng/../search/lib/tika-xmp-1.5.jar:/usr/lib/flume-ng/../search/lib/ua-parser-1.3.0.jar:/usr/lib/flume-ng/../search/lib/vorbis-java-core-0.1.jar:/usr/lib/flume-ng/../search/lib/vorbis-java-core-0.1-tests.jar:/usr/lib/flume-ng/../search/lib/vorbis-java-tika-0.1.jar:/usr/lib/flume-ng/../search/lib/wstx-asl-3.2.7.jar:/usr/lib/flume-ng/../search/lib/xercesImpl-2.9.1.jar:/usr/lib/flume-ng/../search/lib/xml-apis-1.3.04.jar:/usr/lib/flume-ng/../search/lib/xmlbeans-2.6.0.jar:/usr/lib/flume-ng/../search/lib/xmlenc-0.52.jar:/usr/lib/flume-ng/../search/lib/xmpcore-5.1.2.jar:/usr/lib/flume-ng/../search/lib/xz-1.0.jar:/usr/lib/flume-ng/../search/lib/zookeeper.jar' -Djava.library.path=:/usr/lib/hadoop/lib/native:/usr/lib/hadoop/lib/native:/usr/lib/hbase/bin/../lib/native/Linux-amd64-64 org.apache.flume.node.Application -conf-file conf/flumekafka.conf --name agent1
SLF4J: Found binding in [jar:file:/usr/lib/flume-ng/lib/slf4j-log4j12-1.7.5.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/usr/lib/zookeeper/lib/slf4j-log4j12-1.7.5.jar!/org/slf4j/impl/StaticLoggerBinder.class]
2018-03-16 02:06:50,988 (lifecycleSupervisor-1-0) [INFO - org.apache.flume.node.PollingPropertiesFileConfigurationProvider.start(PollingPropertiesFileConfigurationProvider.java:62)] Configuration provider starting
2018-03-16 02:06:51,005 (conf-file-poller-0) [INFO - org.apache.flume.node.PollingPropertiesFileConfigurationProvider$FileWatcherRunnable.run(PollingPropertiesFileConfigurationProvider.java:134)] Reloading configuration file:conf/flumekafka.conf
2018-03-16 02:06:51,025 (conf-file-poller-0) [INFO - org.apache.flume.conf.FlumeConfiguration$AgentConfiguration.addProperty(FlumeConfiguration.java:1016)] Processing:hdfs-sink
2018-03-16 02:06:51,029 (conf-file-poller-0) [INFO - org.apache.flume.conf.FlumeConfiguration$AgentConfiguration.addProperty(FlumeConfiguration.java:1016)] Processing:hdfs-sink
2018-03-16 02:06:51,029 (conf-file-poller-0) [INFO - org.apache.flume.conf.FlumeConfiguration$AgentConfiguration.addProperty(FlumeConfiguration.java:930)] Added sinks: hdfs-sink Agent: agent1
2018-03-16 02:06:51,030 (conf-file-poller-0) [INFO - org.apache.flume.conf.FlumeConfiguration$AgentConfiguration.addProperty(FlumeConfiguration.java:1016)] Processing:hdfs-sink
2018-03-16 02:06:51,095 (conf-file-poller-0) [INFO - org.apache.flume.conf.FlumeConfiguration.validateConfiguration(FlumeConfiguration.java:140)] Post-validation flume configuration contains configuration for agents: [agent1]
2018-03-16 02:06:51,095 (conf-file-poller-0) [INFO - org.apache.flume.node.AbstractConfigurationProvider.loadChannels(AbstractConfigurationProvider.java:147)] Creating channels
2018-03-16 02:06:51,140 (conf-file-poller-0) [INFO - org.apache.flume.channel.DefaultChannelFactory.create(DefaultChannelFactory.java:42)] Creating instance of channel memory-channel type memory
2018-03-16 02:06:51,171 (conf-file-poller-0) [INFO - org.apache.flume.node.AbstractConfigurationProvider.loadChannels(AbstractConfigurationProvider.java:201)] Created channel memory-channel
2018-03-16 02:06:51,172 (conf-file-poller-0) [INFO - org.apache.flume.source.DefaultSourceFactory.create(DefaultSourceFactory.java:41)] Creating instance of source kafka-source, type org.apache.flume.source.kafka.KafkaSource
2018-03-16 02:06:51,209 (conf-file-poller-0) [INFO - org.apache.flume.source.kafka.KafkaSource.doConfigure(KafkaSource.java:400)] Group ID was not specified. Using flume as the group id.
2018-03-16 02:06:51,347 (conf-file-poller-0) [INFO - org.apache.flume.sink.DefaultSinkFactory.create(DefaultSinkFactory.java:42)] Creating instance of sink: hdfs-sink, type: hdfs
2018-03-16 02:06:51,393 (conf-file-poller-0) [INFO - org.apache.flume.node.AbstractConfigurationProvider.getConfiguration(AbstractConfigurationProvider.java:116)] Channel memory-channel connected to [kafka-source, hdfs-sink]
2018-03-16 02:06:51,436 (conf-file-poller-0) [INFO - org.apache.flume.node.Application.startAllComponents(Application.java:137)] Starting new configuration:{ sourceRunners:{kafka-source=PollableSourceRunner: { source:org.apache.flume.source.kafka.KafkaSource{name:kafka-source,state:IDLE} counterGroup:{ name:null counters:{} } }} sinkRunners:{hdfs-sink=SinkRunner: { policy:org.apache.flume.sink.DefaultSinkProcessor@598ef578 counterGroup:{ name:null counters:{} } }} channels:{memory-channel=org.apache.flume.channel.MemoryChannel{name: memory-channel}} }
2018-03-16 02:06:51,450 (conf-file-poller-0) [INFO - org.apache.flume.node.Application.startAllComponents(Application.java:144)] Starting Channel memory-channel
2018-03-16 02:06:51,586 (lifecycleSupervisor-1-0) [INFO - org.apache.flume.instrumentation.MonitoredCounterGroup.register(MonitoredCounterGroup.java:119)] Monitored counter group for type: CHANNEL, name: memory-channel: Successfully registered new MBean.
2018-03-16 02:06:51,587 (lifecycleSupervisor-1-0) [INFO - org.apache.flume.instrumentation.MonitoredCounterGroup.start(MonitoredCounterGroup.java:95)] Component type: CHANNEL, name: memory-channel started
2018-03-16 02:06:51,587 (conf-file-poller-0) [INFO - org.apache.flume.node.Application.startAllComponents(Application.java:171)] Starting Sink hdfs-sink
2018-03-16 02:06:51,589 (lifecycleSupervisor-1-1) [INFO - org.apache.flume.instrumentation.MonitoredCounterGroup.register(MonitoredCounterGroup.java:119)] Monitored counter group for type: SINK, name: hdfs-sink: Successfully registered new MBean.
2018-03-16 02:06:51,589 (lifecycleSupervisor-1-1) [INFO - org.apache.flume.instrumentation.MonitoredCounterGroup.start(MonitoredCounterGroup.java:95)] Component type: SINK, name: hdfs-sink started
2018-03-16 02:06:51,606 (conf-file-poller-0) [INFO - org.apache.flume.node.Application.startAllComponents(Application.java:182)] Starting Source kafka-source
2018-03-16 02:06:51,607 (lifecycleSupervisor-1-2) [INFO - org.apache.flume.source.kafka.KafkaSource.doStart(KafkaSource.java:496)] Starting org.apache.flume.source.kafka.KafkaSource{name:kafka-source,state:IDLE}...
2018-03-16 02:06:51,701 (lifecycleSupervisor-1-2) [INFO - org.apache.kafka.common.config.AbstractConfig.logAll(AbstractConfig.java:171)] ConsumerConfig values:
    check.crcs = true
    ssl.provider = null
    client.id =
    fetch.min.bytes = 1
    ssl.protocol = TLS
    group.id = flume
2018-03-16 02:06:51,909 (lifecycleSupervisor-1-2) [WARN - org.apache.kafka.common.config.AbstractConfig.logUnused(AbstractConfig.java:179)] The configuration groupId = flume was supplied but isn't a known config.
2018-03-16 02:06:51,910 (lifecycleSupervisor-1-2) [WARN - org.apache.kafka.common.config.AbstractConfig.logUnused(AbstractConfig.java:179)] The configuration timeout.ms = 100 was supplied but isn't a known config.
2018-03-16 02:06:51,919 (lifecycleSupervisor-1-2) [INFO - org.apache.kafka.common.utils.AppInfoParser$AppInfo.<init>(AppInfoParser.java:83)] Kafka version : 0.9.0-kafka-2.0.2
2018-03-16 02:06:51,920 (lifecycleSupervisor-1-2) [INFO - org.apache.kafka.common.utils.AppInfoParser$AppInfo.<init>(AppInfoParser.java:84)] Kafka commitId : unknown
There are no errors encountered , but no messages are being written to HDFS. Could someone help. I tried almost every different combination of solution available in the forum.
Thanks in Advance
MMG
me too, I also met this situation.
Sadly I have no new info to provide insight into this issue...but also wanted to callout that we are seeing the same thing on our side.  No errors, just no data movement on the kafka-source -> flume side.
Cloudera Employee
The problem is usually that the kafka consumer is not configured properly, and is failing silently while it is running. You can verify if the flume consumer group is actually connected to partitions by running the
"kafka-consumer-groups" command.
You could also turn on log4j.logger.org.apache.kafka=DEBUG in the broker logging safety valve, and review the messages when flume tries to connect to kafka. A lot of "errors" are retryable, meaning they won't throw an exception, but you won't see any output.
-pd
Great, thank you. I'll take a look at both paths to see if we can narrow down where the issue is occurring.
I'm very confident it's a consumer config issue, but I thought the bare bones config examples on the web would just work, even if not efficiently.
Thanks again...I'll provide an update on how this goes.
New solutions
