Spark -Shell does not start
[ Edited ]
When I try to start spark-shell using Cloudera quick start VM 5.8 and 5.10 it just hangs and does not do anything,
is it any solution available for this.I have attached the screen shot. Any help ?screen shot.PNG
 Spark services are running
Champion
Re: Spark -Shell does not start
[ Edited ]
For some strange reason I cant open ur screenshot .
could you paste the error in the Insert code tag.
Could you let me know if you had set your Java_home path  and Spark_home ?
master and worker node status ?
what type of spark are you trying
  • Standalone - meaning Spark will manage its own cluster
  • YARN - using Hadoop's YARN resource manager
  • Mesos -
try this command  -  in your command line prompt
SPARK_HOME/bin/pyspark
or
SPARK_HOME/bin/spark-shell
Hi,
Thanks for the response. I am using cloudera quick start VM 5.10 with 16 GB RAM.I tried the below path
/usr/lib/spark>spark-shell
However all it says
Service SparkUI could not bind on port 4040.Attempting port 4041
and hangs...means does not proceed further
Contributor
how did you solve this?
