Accepted Solution
quickstart VM connection issues
[ Edited ]
Hi,
I have been using the cloudera quickstart vm for 3 months and have started receiving this error of late when I try to try to run any command on hdfs(hadoop fs -ls / for example). Has anyone come across this before:
**Note :
I have tried restarting the namenode, checking for any errors in the hosts file, restarting the machine--none of this has worked :
 18/02/12 12:43:13 WARN ipc.Client: Failed to connect to server: quickstart.cloudera/127.0.0.1:8020: try once and fail.
java.net.ConnectException: Connection refused
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method)
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:739)
at org.apache.hadoop.net.SocketIOWithTimeout.connect(SocketIOWithTimeout.java:206)
at org.apache.hadoop.net.NetUtils.connect(NetUtils.java:530)
at org.apache.hadoop.net.NetUtils.connect(NetUtils.java:494)
at org.apache.hadoop.ipc.Client$Connection.setupConnection(Client.java:648)
at org.apache.hadoop.ipc.Client$Connection.setupIOstreams(Client.java:744)
at org.apache.hadoop.ipc.Client$Connection.access$3000(Client.java:396)
at org.apache.hadoop.ipc.Client.getConnection(Client.java:1555)
at org.apache.hadoop.ipc.Client.call(Client.java:1478)
at org.apache.hadoop.ipc.Client.call(Client.java:1439)
at org.apache.hadoop.ipc.ProtobufRpcEngine$Invoker.invoke(ProtobufRpcEngine.java:230)
at com.sun.proxy.$Proxy16.getFileInfo(Unknown Source)
at org.apache.hadoop.hdfs.protocolPB.ClientNamenodeProtocolTranslatorPB.getFileInfo(ClientNamenodeProtocolTranslatorPB.java:771)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.apache.hadoop.io.retry.RetryInvocationHandler.invokeMethod(RetryInvocationHandler.java:260)
at org.apache.hadoop.io.retry.RetryInvocationHandler.invoke(RetryInvocationHandler.java:104)
at com.sun.proxy.$Proxy17.getFileInfo(Unknown Source)
at org.apache.hadoop.hdfs.DFSClient.getFileInfo(DFSClient.java:2126)
at org.apache.hadoop.hdfs.DistributedFileSystem$20.doCall(DistributedFileSystem.java:1262)
at org.apache.hadoop.hdfs.DistributedFileSystem$20.doCall(DistributedFileSystem.java:1258)
at org.apache.hadoop.fs.FileSystemLinkResolver.resolve(FileSystemLinkResolver.java:81)
at org.apache.hadoop.hdfs.DistributedFileSystem.getFileStatus(DistributedFileSystem.java:1258)
at org.apache.hadoop.fs.Globber.getFileStatus(Globber.java:64)
at org.apache.hadoop.fs.Globber.doGlob(Globber.java:272)
at org.apache.hadoop.fs.Globber.glob(Globber.java:151)
at org.apache.hadoop.fs.FileSystem.globStatus(FileSystem.java:1715)
at org.apache.hadoop.fs.shell.PathData.expandAsGlob(PathData.java:326)
at org.apache.hadoop.fs.shell.Command.expandArgument(Command.java:235)
at org.apache.hadoop.fs.shell.Command.expandArguments(Command.java:218)
at org.apache.hadoop.fs.shell.FsCommand.processRawArguments(FsCommand.java:102)
at org.apache.hadoop.fs.shell.Command.run(Command.java:165)
at org.apache.hadoop.fs.FsShell.run(FsShell.java:315)
at org.apache.hadoop.util.ToolRunner.run(ToolRunner.java:70)
at org.apache.hadoop.util.ToolRunner.run(ToolRunner.java:84)
at org.apache.hadoop.fs.FsShell.main(FsShell.java:372)
ls: Call From quickstart.cloudera/127.0.0.1 to quickstart.cloudera:8020 failed on connection exception: java.net.ConnectException: Connection refused; For more details see: http://wiki.apache.org/hadoop/ConnectionRefused
Thanks for the Help
Nithin
Re: quickstart VM connection issues
Found solution:
https://community.hortonworks.com/questions/7455/namenode-can-not-be-started.html
Found this error in the namenode logs : /var/logs/hadoop/, the error was Failed to load image from FSImageFile(file=/var/lib/hadoop-hdfs/cache/hdfs/dfs/name/current/fsimage_****, cpktTxId=0000000000000425183)
Went to the mentioned location and deleted the FS image which was 0 Bytes, see above link. Restarted the namenode and datanodes and everythings works as expected.
Thanks!
