How to manage Impala connection exhaustion
Hello team,
We have different applications/scripts that are fetching data via Impala.
These are jdbc connections. The output of the queries ends up with exceptions
Caused by: com.cloudera.support.exceptions.GeneralException: [Simba][ImpalaJDBCDriver](500051) ERROR processing query/statement. Error Code: null, SQL state: HY000,
The issue gets resolved after a service restart of Impala.
Is there a way to check how many open connections ? Please let us know.
Thanks and regards
Sayak
Master
Re: How to manage Impala connection exhaustion
You can try to monitor the number of queries in the Impala Daemon's web ui.
Thank you. Is there any other way apart from web ui. Like from command interface ?
Master
No, but you can easily write a script to get those data from the Impala Daemon rest api
Champion
If you are looking for number of sessions against HS2 in impala you can use the chart library that you can found in CM -> IMPALA -> Chart library - >
Cloudera Employee
You might also create triggers in CM by going to CM > Impala > Charts on the right hand side > Queries Across Impala Daemons
And then follow on screen instructions.
More details here:
https://www.cloudera.com/documentation/enterprise/latest/topics/cm_dg_triggers.html
Contributor
You should look at fe_service_threads, what is your current setting and consider increasing it if needed. When you are seeing exception/timeout on connection have a look at dashboard using following ts_query
'select thrift_server_hiveserver2_frontend_connections_in_use' if this value is approaching the default setting of fe_service_threads then you know your running out of connections. The default setting can be viewed in the service page/varz.
