PD
Accepted Solution
Impala String Date - greater than or less than command to query tables
Hi All,
I have a date which is stored as string and we would like to query it in Impala using greater than or less than functionality , however i am having no luck and when i play around unixtimestamp/timestamp
it returns as Null values.
e.g. select * from table T1 where orderdate is less than < 1/1/2001
order date is stored as string in T1 and doesnot have padded zeroes : 1/1/2001 (and not 01/01/2001)
SELECT
cast(unix_timestamp(`date`, "MM/dd/yyyy") as timestamp), `date` FROM T1 ;
Result --  Null values for cast command
SELECT * FROM T1 WHERE start = '"4/3/2015"' ;
Result - No data
SELECT * FROM T1 WHERE start > "4/3/2015" ;
Result - No data
Master
Re: Impala String Date - greater than or less than command to query tables
Hi, it is not so common to have a date in this format, but it is possible to convert it into timestamp in Impala.
Your approach was good, just used a wrong format:
> CORRECT FORMAT
[10.197.0.1:21000] > select *, cast( unix_timestamp(s, "M/d/yyyy") as timestamp ) from work.t;
| id  | s          | cast(unix_timestamp(s, 'm/d/yyyy') as timestamp) |
| 100 | 12/24/2018 | 2018-12-24 00:00:00                              |
| 200 | 3/24/2018  | 2018-03-24 00:00:00                              |
Fetched 2 row(s) in 0.33s
> THIS IS A WRONG FORMAT
[10.197.0.1:21000] > select *, cast( unix_timestamp(s, "MM/dd/yyyy") as timestamp ) from work.t;
| id  | s          | cast(unix_timestamp(s, 'mm/dd/yyyy') as timestamp) |
| 200 | 3/24/2018  | NULL                                               |
Convert the string to a date and then you can use a correct where conditions.
PD
Thank you :) that resolved it for me.
