Issues Creating Impala ODBC DSN using odbcconf
I am trying to automate the configuration of client Windows 7-10 PCs that need to connect to Impala through ODBC. I am trying to use odbcconf, but running into an issue that appears to be specific to the Impala driver.
When I run the following command, a ODBC configuration window pops up, which has no configuration in it at all. When I run it for a SQL Server DSN, however, it returns immediately, and I can see the DSN in ODBC Administrator. The only difference is the driver. See below for the command and a screenshot of what I see.
odbcconf CONFIGSYSDSN "Cloudera ODBC Driver for Impala" "DSN=Testing|Server=server"
Any ideas on what I need to do in order to allow for the creation of an Impala DSN using odbcconf?
Our community is getting a little larger. And a lot better.
Learn More about the Cloudera and Hortonworks community merger planned for late July and early August.
