Java connection not working JDBC + SSL + LDAP [ImpalaJDBCDriver](500310) Invalid operation: null;
[ Edited ]
Dear all
I am trying to connect to Impala using the JDBC driver from a Jetty App
Whatever i do i get a non informative error back
Caused by: java.sql.SQLException: [Simba][ImpalaJDBCDriver](500310) Invalid operation: null;
        at com.cloudera.impala.hivecommon.api.HiveServer2ClientFactory.createTransport(HiveServer2ClientFactory.java:224)
My latest connection string :
jdbc:impala://host.muc.infineon.com:21050/mydb;AuthMech=3;SSL=1;AllowSelfSignedCerts=1;CAIssuedCertsMismatch=1;UID=myuser;PWD=xxxxxxx;SSLKeyStore=/xxxxx/jetty/mondrian.jks;SSLKeyStorePwd=xxxxxx;LogLevel=6;LogPath=/xxxxxxx/jetty;SocketTimeout=0
I started with the basic:
jdbc:impala://host.muc.infineon.com:21050/mydb;AuthMech=3;SSL=1;AllowSelfSignedCerts=1;UID=myuser;PWD=xxxxxxx;
which works well in other clients that also are using the same driver version
I kept adding parameters to see if it would help.
At the moment i dont even have any clue even on how to debug further.
Any help would be apreciated.
Re: Java connection not working JDBC + SSL + LDAP [ImpalaJDBCDriver](500310) Invalid operation: nul
Update:
I was able to fix the problem by downloading the latest JDBC drivers, removing the old . Also, seems the new version of the driver does not require additional jars to be added .
Our community is getting a little larger. And a lot better.
Learn More about the Cloudera and Hortonworks community merger planned for late July and early August.
