Support Questions
How to read delta records from MS SQL using NiFi/HDF
I have a few tables in MS SQL, these tables gets updated every second and query more or less look like this
SELECT G_ID,UpdateTime,ID,Name,T_NAME FROM TABLE1 AS table1 INNER JOIN TABLE2 AS table2 ON table1.IP=table2.ID WHERE table2.UpdateTime >= ${lastUpdateTime} AND table2.G_ID > ${lastID}
Let assume the select inner join query results 5 records as shown in Capture1 image If the query runs for the first time ${lastUpdateTime} and ${lastG_ID} is set to 0, and it will return below 5 records. After processing the records, the query will store the max (G_ID) i.e. 5 and max (UpdateTime) i.e. 1512010479 in "etl_stat" table
if table add another 5 new records as shown in Capture2 image:
The query will read first the max(G_ID) and max(UpdateTime) from "etl_stat table" and will frame query as follows
SELECT G_ID,UpdateTime,ID,Name,T_NAME FROM TABLE1 AS table1 INNER JOIN TABLE2 AS table2 ON table1.IP=table2.ID  WHERE table2.UpdateTime >= 1512010479 AND table2.G_ID > 5
So that the query returns only 5 delta records as shown in Capture3 image.
So Every time a query run it should first read the max (G_ID) and max (UpdateTime) from etl_stat table and frame the select inner join query as shown above and get the delta changes.
AS IS ARCHITECTURE USING SPARK SQL:
I have implemented the above use case as follows:
1) Spark JDBC reads phoenix table to get the max(G_ID) and max(UpdateTime) from etl_stat table.
2) Spark JDBC frames the select inner join query like this
3) Spark JDBC runs step 2 inner join query, reads the delta messages from MS SQL server process the records and inserts into HBase.
4) After successful insert into HBase, Spark update the etl_stat table with latest G_ID i.e. 10 and UpdateTime i.e. 1512010500.
5) This job has been cron scheduled to run every 1 minute.
TO BE ARCHITECTURE USING NIFI:
I want to move this use case to Nifi, I want to use NiFi to read records from MS SQL DB and send this record to Kafka.
After successfully publish to Kafka, NiFi will save G_ID and UpdateTime in the database. Once message will reach to Kafka, spark streaming will read messages from Kafka and will save to HBase using existing business logic.
On every run Nifi processor should frame select inner join query using max(G_ID) and max(UpdateTime) in order to get delta records and publish to Kafka. I am new to Nifi/HDF.
I need your help and guidance in order to implement this using Nifi/HDF. if you have better solution/architecture for this use case please suggest.
Sorry for such a long post.
5 REPLIES 5
Re: How to read delta records from MS SQL using NiFi/HDF
Hi @Nilesh Pandey
QuerydatabaseTable has native support for delta : https://nifi.apache.org/docs/nifi-docs/components/org.apache.nifi/nifi-standard-nar/1.4.0/org.apache...
You can use the Maximum-value Columns to define what are the columns to use in order to detect new lines. NiFi manages an internal state to save the last values, and will get row from this state each time.
Can ou look to this processor and see if it helps ?
@Abdelkrim Hadjidj Thank you for the quick response , I will check at my end and let you know.Just one more thing ..do you see this as better architecture as compared to the AS IS one ?
Hi @Abdelkrim Hadjidj If possible can you please share how to set QueryDatabaseTable w.r.t to my query and columns, I am not able to see any field where I can enter my select inner join query QueryDatabaseTable processor.
Hi @Abdelkrim Hadjid I am not able to use QuerydatabaseTable for this use case, as mentioned in my previous comment. Can you please help me on this I am badly stuck on this.
Hi @Nilesh Pandey from your answer I get that your problem was with a row version column. Were you able to solve the issue? I'm facing exactly the same problem.
Don't have an account?
