Support Questions
Issue running Impala Shell Commands with Oozie
Hi,
When I run Impala shell commands with Oozie workflow based on the steps recommended here:
http://community.cloudera.com/t5/Interactive-Short-cycle-SQL/Impala-schedule-with-oozie-tutorial/td-...
https://community.cloudera.com/t5/Interactive-Short-cycle-SQL/How-to-Schedule-Impala-Jobs-with-Oozie...
I am getting an error thrown:
File "/app/localstorage/parcels/CDH-5.12.1-1.cdh5.12.1.p0.3/bin/../lib/impala-shell/impala_shell.py", line 38, in
<module>
from impala_client import (ImpalaClient, DisconnectedException, QueryStateException,
File "/app/localstorage/parcels/CDH-5.12.1-1.cdh5.12.1.p0.3/lib/impala-shell/lib/impala_client.py", line 20, in <
module>
import sasl
File "/app/localstorage/parcels/CDH-5.12.1-1.cdh5.12.1.p0.3/lib/impala-shell/ext-py/sasl-0.1.1-py2.7-linux-x86_64
.egg/sasl/__init__.py", line 1, in <module>
.egg/sasl/saslwrapper.py", line 7, in <module>
.egg/_saslwrapper.py", line 7, in <module>
.egg/_saslwrapper.py", line 6, in __bootstrap__
ImportError: /tmp/impala-shell-python-egg-cache-subuser/sasl-0.1.1-py2.7-linux-x86_64.egg-tmp/_saslwrapper.so: fail
ed to map segment from shared object: Operation not permitted
We are using kerberos and this folder has 777 permission, but still throwing this error.
How do we resolve this?
1 ACCEPTED SOLUTION
Problem Solved
The issue was that the script /bin/impala_shell is hardcoded by cloudera on our nodes, and so the PYTHON_EGG_CACHE always got redefined to /tmp
Below is a snippet of the code in /bin/impala_shell:
# We should set the EGG_CACHE to a per-user temporary location.
# This follows what hue does.
PYTHON_EGG_CACHE=/tmp/impala-shell-python-egg-cache-${USER}
if [ ! -d ${PYTHON_EGG_CACHE} ]; then
  mkdir ${PYTHON_EGG_CACHE}
fi
Additionally, /tmp was not exec mounted on all nodes.
In order to solve the issue we were having, we added the below code to the impala shell script that we want to run with oozie:
export PYTHON_EGG_CACHE=/app/bds
export link_folder=/tmp/impala-shell-python-egg-cache-$(whoami)
if ! [ -L $link_folder ]
then
    rm -Rf "$link_folder"
    ln -sfn ${PYTHON_EGG_CACHE}${link_folder} ${link_folder}
fi
mkdir -p ${PYTHON_EGG_CACHE}${link_folder}
This creates a new link dir for PYTHON_EGG_CACHE, on a shared folder, which can be accessed by all nodes.
1 REPLY 1
Problem Solved
fi
then
fi
