Support Questions
Not able to connect to jmx metric running on HDP sandbox using jconsole remotely
I added following properties to hbase-site.xml
<property>
<name>hbase.coprocessor.regionserver.classes</name>
<value>org.apache.hadoop.hbase.JMXListener</value>
</property>
<property>
<name>regionserver.rmi.registry.port</name>
<value>61130</value>
</property>
<property>
<name>regionserver.rmi.connector.port</name>
<value>61140</value>
</property>
Added following config to hbase-env
export HBASE_JMX_BASE="-Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.authenticate=false"
export HBASE_MASTER_OPTS="$HBASE_MASTER_OPTS $HBASE_JMX_BASE"
export HBASE_REGIONSERVER_OPTS="$HBASE_REGIONSERVER_OPTS $HBASE_JMX_BASE"
10 REPLIES 10
Re: Not able to connect to jmx metric running on HDP sandbox using jconsole remotely
Are you able to do telnet or nc(netcat) from the remote machine on this host and port?
Getting connection refused while trying to connect using telnet. I have HDP sandbox on same machine.
@Tushar Patil
You should add the "-Dcom.sun.management.jmxremote.port=portNum" and then try to connect to that port using jconsole like:
export HBASE_JMX_BASE="-Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.authenticate=false  -Dcom.sun.management.jmxremote  -Dcom.sun.management.jmxremote.port=5555"
@jk
I tried the approach that you have suggested but no success.
Currently i have following configuration in hbase-env,
export HBASE_JMX_BASE="-Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.authenticate=false" export HBASE_MASTER_OPTS="$HBASE_JMX_BASE -Dcom.sun.management.jmxremote.port=10101" export HBASE_REGIONSERVER_OPTS="$HBASE_JMX_BASE -Dcom.sun.management.jmxremote.port=10102"
And following in hbase-site
<property> <name>hbase.coprocessor.regionserver.classes</name> <value>org.apache.hadoop.hbase.JMXListener</value> </property> <property> <name>regionserver.rmi.registry.port</name> <value>61130</value> </property>
And added 10102 and 61130 in port forwarding in sandbox.
If you cannot use telnet or nc to connect to the port in the Sandbox from your physical machine, there is a networking issue. You can try using the RegionServer RPC port to test connectivity (16020).
Also, use `netstat` on the Sandbox to verify that the ports are not bound only on localhost (which might prevent the VM networking from properly forwarding the port).
@Josh Elser
telnet -d 127.0.0.1 10102
I used telnet with 10102 port and got output given below,
Trying 127.0.0.1...
setsockopt (SO_DEBUG): Permission denied
Connected to 127.0.0.1.
Are you running that from inside the Sandbox or your host machine? You would want to make sure that you can do that test from your host machine into the virtual machine.
@Josh Elser
I running telnet from host machine.
@Josh Elser
Hi Josh,
Are below configurations are correct to enable jmx on sandbox(hbase version - 1.1.2)
<property>
</property>
<property>
</property>
<property>
</property>
Don't have an account?
