- Subscribe to RSS Feed
- Mark Question as New
- Mark Question as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
Problem in running coordinator [oozie-site.xml issue]
- Labels:
Apache Ambari
Apache Oozie
Created 06-19-2017 08:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
hi,
I have a workflow that I've ran it successfully earlier. now I need a coordinator to schedule it.
my command is:
oozie job --oozie http://node3:11000/oozie --config '/usr/hdp/current/oozie-server/sqoop-sample/test02/job.properties' -D oozie.wf.application.path=hdfs://node2:8020/user/root/test/sqoop/coordinator.xml -run
my workflow is:
<?xml version="1.0" encoding="UTF-8"?> <workflow-app xmlns="uri:oozie:workflow:0.2" name="sqoop-wf"> <start to="sqoop-node"/> <action name="sqoop-node"> <sqoop xmlns="uri:oozie:sqoop-action:0.2"> <job-tracker>${jobTracker}</job-tracker> <name-node>${nameNode}</name-node> <prepare> <delete path="${nameNode}/user/${wf:user()}/${examplesRoot}/output-data/sqoop"/> <mkdir path="${nameNode}/user/${wf:user()}/${examplesRoot}/output-data"/> </prepare> <configuration> <property> <name>mapred.job.queue.name</name> <value>${queueName}</value> </property> </configuration> <command>import --driver com.mysql.jdbc.Driver --connect jdbc:mysql://node1/mydb --table topop --target-dir /user/root/testdata2 --username user --password mypassword -m 1</command> </sqoop> <ok to="end"/> <error to="fail"/> </action> <kill name="fail"> <message>Sqoop failed, error message</message> </kill> <end name="end"/> </workflow-app>
here is coordinator.xml:
<?xml version="1.0" encoding="UTF-8"?> <coordinator-app xmlns="uri:oozie:coordinator:0.2" name="sqoop-wf" frequency="${coord:days(1)}" start="2017-06-18T12:50Z" end="2018-06-18T12:15Z" timezone="United_kingdom/London"> <action> <workflow> <app-path>${nameNode}/user/root/test/sqoop</app-path> </workflow> </action> </coordinator-app>
and finally oozie-site.xml:
<configuration> <property> <name>oozie.action.retry.interval</name> <value>30</value> </property> <property> <name>oozie.authentication.simple.anonymous.allowed</name> <value>true</value> </property> <property> <name>oozie.authentication.type</name> <value>simple</value> </property> <property> <name>oozie.base.url</name> <value>http://node3:11000/oozie</value> </property> <property> <name>oozie.credentials.credentialclasses</name> <value>hcat=org.apache.oozie.action.hadoop.HCatCredentials,hive2=org.apache.oozie.action.hadoop.Hive2Credentials</value> </property> <property> <name>oozie.db.schema.name</name> <value>oozie</value> </property> <property> <name>oozie.service.ActionService.executor.ext.classes</name> <value>org.apache.oozie.action.email.EmailActionExecutor, org.apache.oozie.action.hadoop.HiveActionExecutor, org.apache.oozie.action.hadoop.ShellActionExecutor, org.apache.oozie.action.hadoop.SqoopActionExecutor</value> </property> <property> <name>oozie.service.AuthorizationService.security.enabled</name> <value>true</value> </property> <property> <name>oozie.service.HadoopAccessorService.hadoop.configurations</name> <value>*=/usr/hdp/current/hadoop-client/conf</value> </property> <property> <name>oozie.service.HadoopAccessorService.kerberos.enabled</name> <value>false</value> </property> <property> <name>oozie.service.JPAService.jdbc.driver</name> <value>com.mysql.jdbc.Driver</value> </property> <property> <name>oozie.service.JPAService.jdbc.password</name> <value>SECRET:oozie-site:12:oozie.service.JPAService.jdbc.password</value> </property> <property> <name>oozie.service.JPAService.jdbc.url</name> <value>jdbc:mysql://node1/oozie</value> </property> <property> <name>oozie.service.JPAService.jdbc.username</name> <value>root</value> </property> <property> <name>oozie.service.SchemaService.wf.ext.schemas</name> <value>shell-action-0.1.xsd,email-action-0.1.xsd,hive-action-0.2.xsd,sqoop-action-0.2.xsd,ssh-action-0.1.xsd,oozie-coordinator-0.2.xsd,oozie-workflow-0.5.xsd</value> </property> <property> <name>oozie.service.SparkConfigurationService.spark.configurations</name> <value>*=spark-conf</value> </property> <property> <name>oozie.service.URIHandlerService.uri.handlers</name> <value>org.apache.oozie.dependency.FSURIHandler,org.apache.oozie.dependency.HCatURIHandler</value> </property> <property> <name>oozie.services.ext</name> <value>org.apache.oozie.service.JMSAccessorService,org.apache.oozie.service.PartitionDependencyManagerService,org.apache.oozie.service.HCatAccessorService,org.apache.oozie.service.ActionService</value> </property> </configuration>
and the error msg:
Error: E0723 : E0723: Unsupported action type, node [workflow] type [org.apache.oozie.service.ActionService]
any idea?
Created 06-19-2017 06:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you try include xmlns="uri:oozie:coordinator:0.4" after the timezone="United_kingdom/London"?
Created 06-20-2017 05:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I tried but the same error appeared. have you ran a coordinator successfully? if yes, can you provide your oozie-site.xml file? I think my problem derives from there. but I don't know what is missing or misconfigured.
Created 06-24-2017 09:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I changed my command like:
oozie job --oozie http://node3:11000/oozie --config '/usr/hdp/current/oozie-server/sqoop-sample/test02/job.properties' -D oozie.coord.application.path=hdfs://node2:8020/user/root/test/sqoop/coordinator.xml -run
and done.
Created 10-23-2018 08:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@Sara Alizadeh - Command is same as what you have given in the question. Can you please let us know what changed to fix this?
Created 11-12-2018 06:16 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Well...the command is not the same.
This time I used oozie.coord.application.path instead of oozie.wf.application.path.
