Support Questions
Problem with Atlas hook for Storm is enabled: submitting a Storm topology using SAM fails due to java.lang.ClassNotFoundException
Hello Guys,
I have setup a standard HDP 2.6.1.0 & HDF 3.0 cluster.
I have enabled the Storm hook for Atlas in Storm config using Ambari. When I disable the hook everything works fine.
But when the hook is enabled, I can not submit a topology anymore failing with the following error message in SAM UI:
Topology submission failed due to: java.lang.Exception: Topology could not be deployed successfully: storm deploy command failed with Exception in thread "main" org.apache.storm.hooks.SubmitterHookException: java.lang.ClassNotFoundException: org.apache.atlas.storm.hook.StormAtlasHook
I have checked on the Storm and all worker nodes that the following jar files are available in /usr/hdp/current/storm-client/extlib as symlink:
lrwxrwxrwx1 root root atlas-plugin-classloader-0.8.0.2.6.1.0-129.jar -> /usr/hdp/current/atlas-server/hook/storm/atlas-plugin-classloader-0.8.0.2.6.1.0-129.jar
lrwxrwxrwx1 root root storm-bridge-shim-0.8.0.2.6.1.0-129.jar -> /usr/hdp/current/atlas-server/hook/storm/storm-bridge-shim-0.8.0.2.6.1.0-129.jar
This is the result of the OOTB Ambari installation and I have installed it fresh - no upgrade.
The java lib path looks like this:
java.library.path /usr/local/lib:/opt/local/lib:/usr/lib:/usr/hdp/current/storm-client/lib:/usr/hdp/current/storm-client/extlib
So the required jar files are in the build path, right? Could it be a permission issue?
Any ideas? I am deploying the Storm topology using Streaming Analytics Manager running on the same host as Storm.
BR,
Alexander
Don't have an account?
