Support Questions
Problem with hbase classpath within s spark job (cloudera quickstart)
Champion Alumni
I'm having a simple spark job (done in java) that I'm executing on a cloudera quickstart plateform (learning phase) and I wanted to create a hbase table.
However hbase/zookeeper is not found:
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/hadoop/hbase/ZooKeeperConnectionException
           at java.lang.Class.forName0(Native Method)
           at java.lang.Class.forName(Class.java:270)
           at org.apache.spark.deploy.SparkSubmit$.launch(SparkSubmit.scala:319)
           at org.apache.spark.deploy.SparkSubmit$.main(SparkSubmit.scala:75)
Caused by: java.lang.ClassNotFoundException: org.apache.hadoop.hbase.ZooKeeperConnectionException
           at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
           at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
           at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
           at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
           at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
I tried to set the HBASE_CLASSPATH from the /usr/lib/hbase/conf/hbase-env.sh to /usr/lib/hbase/ but it didn't worked.
My code:
	Configuration conf = HBaseConfiguration.create();
		try {
			HBaseAdmin admin = new HBaseAdmin(conf);
		} catch (MasterNotRunningException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
		} catch (ZooKeeperConnectionException e) {
		} catch (IOException e) {
		HTableDescriptor tableDescriptor = new HTableDescriptor(TableName.valueOf("people"));
What should I do?
Thank you!
GHERMAN Alina
4 REPLIES 4
Re: Problem with hbase classpath within s spark job (cloudera quickstart)
Champion Alumni
I forgot to say that I also tried to add:
<property>
      <name>hbase.zookeeper.property.dataDir</name>
      <value>usr/local/zookeeper</value>
  </property>
  <property>
      <name>hbase.zookeeper.property.clientPort</name>
      <value>2181</value>
  </property>
 in my hbase-env.sh script (before that, in this script there was nothing concerning zookeeper)
Thank you!
GHERMAN Alina
Champion Alumni
And my pom is containg the folowing components:
	<dependency><!-- hbase -->
			<groupId>org.apache.hbase</groupId>
			<artifactId>hbase-server</artifactId>
			<version>${hbase.version}</version>
			<scope>provided</scope>
		</dependency>
			<artifactId>hbase-common</artifactId>
		</dependency>
			<artifactId>hbase-client</artifactId>
		</dependency>
		<dependency><!-- zookeeper -->
			<groupId>org.apache.zookeeper</groupId>
			<artifactId>zookeeper</artifactId>
			<version>${zookeeper.version}</version>
		</dependency>
GHERMAN Alina
Could you please try setting:
$ export SPARK_CLASSPATH=$SPARK_CLASSPATH:`hbase classpath`
Ensure the value contains /etc/hbase/conf as well, otherwise append it to the list. Do let us know if this solved your problem
Regards,
Gautam Gopalakrishnan
It doesn't solve the problem. My HBASE configuration was in different directory other than /etc/hbase/conf but as you suggsted to append the SPARK_CLASSPATH with the HBASE configuration path. I did the same in my enviornment but it didn't work.
What I'm trying here - I've Spark2.3 R3 installed on Cloudera Platform and trying to connect HBASE which is running on different cluster. It's throwing an exception "hbase package is not a member of org.apache.hadoop package" while running Spark2.3
Can you please sugguest me how I pass the HBASE configuration/libraries to Spark2.3
Don't have an account?
