Support Questions
SSO solution for a dynamic web project
I want to achieve the sso for dynamic web project via knox. Has anyone ever tried this?
Thanks
1 REPLY 1
Guru
Not clear what the technical architecture is for your solution, but Knox is designed specifically to provide SSO to cluster access and thus your solution.
"KnoxSSO provides an abstraction for integrating any number of authentication systems and SSO solutions, and enables participating web applications to scale to those solutions more easily. Without the token exchange capabilities offered by KnoxSSO, each component UI would need to integrate with each desired solution on its own. With KnoxSSO, they only need to integrate with the single solution and common token."
https://docs.hortonworks.com/HDPDocuments/HDP2/HDP-2.6.1/bk_security/content/knox_sso.html
Take a Tour of the Community
Don't have an account?
Your experience may be limited. Sign in to explore more.
