Support Questions
Tez Engine is failing while running hive query, with below error. Please help ?
New Member
hive> SELECT COUNT(*) FROM student;
Query ID = 3d50f624-68eb-48b5-a0c4-33697da38e91
Total jobs = 1
Launching Job 1 out of 1
Tez session was closed. Reopening...
FAILED: Execution Error, return code 1 from org.apache.hadoop.hive.ql.exec.tez.TezTask
hive>
Total jobs = 1
hive>
4 REPLIES 4
Guru
you can launch hive in a debug session mode to have more info
hive --hiveconf hive.root.logger=INFO,console
New Member
Check /tmp/hive for hive log and you will see the error stacktrace there.
Rising Star
Try changing the execution engine to MR.. Run your query.. If its working fine. Change the execution engine to tez.
this is how you do it.
set hive.execution.engine=mr;
set hive.execution.engine=tez;
New Member
are you on hive2? if yes try providing queue name to the host
beeline -u jdbcLhive2://<localhost>:10000?ez.queue.name=<queuename> -n hive -e "select count(*) from student"
