Support Questions
Alert: Welcome to the Unified Cloudera Community. Former HCC members be sure to read and learn how to activate your account here. Want to know more about what has changed? Check out the Community News blog.
dataframe to avro read write issue
I am trying to write a dataframe to avro using databricks scala api. The writing is successful. But while reading the data from hive it is throwing exception:
Error: java.io.IOException: org.apache.hadoop.hive.serde2.avro.AvroSerdeException: Failed to obtain scale value from file schema: "bytes" (state=,code=0)
In the avsc file I have column wityh type byte:
{"name":"rate","type":["null",{"type":"bytes","logicalType":"decimal","precision":38,"scale":18}],"default":null}
reading
val df = sqlContext.read.format("com.databricks.spark.avro")
.option("avroSchema", schema.toString)
.option("inferSchema", "true")
.avro(sourceFile)
.filter(preparePartitionFilterClause);
writing
df.write.mode(SaveMode.Append).format("com.databricks.spark.avro").partitionBy(TrlConstants.PARTITION_COLUMN_COUNTRYCODE).save(path);
I am completely clue less please help!!!
