Support Questions
Check out our newest addition to the community, the Cloudera Innovation Accelerator group hub.
sqoop into more parts with small sizes
I have sqoop stmt with 10 mappers. All the data is going into 10 parts in hadoop with each part exceeding the 1GB. I want to divide the data in multiple files of smaller parts, needless to say more than 10, something like 50 files of 200MB each. However due to DB bottleneck issue, I cant create more than 10 mappers in a sqoop. Let me know if their is any easy solution.
1 REPLY 1
Super Guru
@Pavan Ebbadi
Have you tried --direct-split-size to limit the size of the files written? It takes an argument in bytes so you would give --direct-split-size 200000000
