Re: Running shell scripts in oozie using hue
[ Edited ]
Hi all,
Which lib folder of oozie workflow should we place the script in? Are there changes in Hue 4.0?
I am running it via Shell Editor in Hue 4.0 and CDH 5.13 using hive user, I tried to put the script in folders:
- /user/hive/oozie-oozi/test.sh
- /user/hue/oozie/workspaces/hue-oozie-xxxxxxxxx.52/lib
- /user/oozie/share/lib/lib_20171122100655/oozie
http://gethue.com/use-the-shell-action-in-oozie/ - this also doesn't apply, as I have Hue 4.0 and Shell Editor requires a Script Path. So as I am giving in a Shell Editor a path to the script, which file or directory is oozie workflow looking for?
I have the same error message as was posted in a first post.
Failing Oozie Launcher, Main class [org.apache.oozie.action.hadoop.ShellMain], main() threw exception, Cannot run program "test.sh" (in directory "/yarn/nm/usercache/hive/appcache/application_1515668016860_0017/container_1515668016860_0017_01_000002"): error=2, No such file or directory
java.io.IOException: Cannot run program "test.sh" (in directory "/yarn/nm/usercache/hive/appcache/application_1515668016860_0017/container_1515668016860_0017_01_000002"): error=2, No such file or directory
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1047)
	at org.apache.oozie.action.hadoop.ShellMain.execute(ShellMain.java:111)
	at org.apache.oozie.action.hadoop.ShellMain.run(ShellMain.java:70)
	at org.apache.oozie.action.hadoop.LauncherMain.run(LauncherMain.java:81)
	at org.apache.oozie.action.hadoop.ShellMain.main(ShellMain.java:59)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.apache.oozie.action.hadoop.LauncherMapper.map(LauncherMapper.java:235)
	at org.apache.hadoop.mapred.MapRunner.run(MapRunner.java:54)
	at org.apache.hadoop.mapred.MapTask.runOldMapper(MapTask.java:459)
	at org.apache.hadoop.mapred.MapTask.run(MapTask.java:343)
	at org.apache.hadoop.mapred.YarnChild$2.run(YarnChild.java:164)
	at javax.security.auth.Subject.doAs(Subject.java:415)
	at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1917)
	at org.apache.hadoop.mapred.YarnChild.main(YarnChild.java:158)
Caused by: java.io.IOException: error=2, No such file or directory
	at java.lang.UNIXProcess.forkAndExec(Native Method)
	at java.lang.UNIXProcess.<init>(UNIXProcess.java:186)
	at java.lang.ProcessImpl.start(ProcessImpl.java:130)
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1028)
	... 17 more
Does anyone know why I cannot run a script?
Is there anyone solve this issue?
Still having same issue
Ye even  I cannot run shell jobs thru HUE. CAn anyone help.?
