dvh
running parallel jobs in HUE raise packet_write_wait: Connection to UNKNOWN port 0: Broken pipe
Error in DataNode & NameNode
but when "running jobs is linear" is working fine.
any idea to fix this
Topics: 3
Kudos: 120
Solutions: 67
Re: running parallel jobs in HUE raise packet_write_wait: Connection to UNKNOWN port 0: Broken pipe
Do you mean connecting to Hue concurrently? Or is that fine but multiple users running jobs concurrently? Does the latter work outside of Hue?
what is your backend DB for Hue? I believe the default derby db has concurrency issues.
dvh
Q: Do you mean connecting to Hue concurrently?
No , i mean running jobs parallelly under only one user.
Q: is that fine but multiple users running jobs concurrently
I didn't test with multiple user. i am running only one main job (parallelly 5x5 times) from a single user.
that means that one main job splitted into 5 groups and each group can have 5 sub-jobs. when the main job is running it will take one group at a time and run all 5 sub-jobs parallelly by creating individual "ssh connection session" under "ssh user@hadoop_en" .
Q: Does the latter work outside of Hue?
yes, i can "ssh user@hadoop_en"  into that node and run that main job (sh main_job.sh) directly then the job was working fine.
Q: what is your backend DB for Hue?
Default
Here is my configuration
Hue™ 3.9.0 - The Hadoop UI
Learn more about Hue and Hadoop on http://gethue.com. Hue and the Hue logo are trademarks of Cloudera, Inc.
Here is what i have done:
When i go to Workflows > Dashboards > Coordinators in web-UI
i can see many of our developer's jobs.
when i run one job (parallel jobs) the job getting failed.
after that i can't able to ssh into that node for that particular user by "ssh user@hadoop_en".
when i try to "ssh user@hadoop_en", i am getting this error
but i can able to "ssh any_other_user@hadoop_en".
Any help ?
Topics: 3
Kudos: 120
Solutions: 67
It sound like this is an issue specifically with SSH. I don't recognize the specific error. Try digging through the sshd man page or the various settings in sshd_config. Something in it may be limiting the number of connections per user.
