226b1e5f-0160-1000-deb0-791f1a6f1f00
Json to Avro conversion using ConvertJSONToAvro processor
edd6caa2-f670-3619-0000-000000000000
e2b40252-d013-3b63-0000-000000000000
1 GB
10000
374.94467144034206
624.2153383995164
7da1c636-ce9a-3733-0000-000000000000
FUNNEL
0 sec
1
failure
0
ee925564-7e49-3889-0000-000000000000
1 GB
10000
FUNNEL
0 sec
1
success
0
1c7299bc-c9e7-3535-0000-000000000000
1 GB
10000
9844c4f6-8505-3680-0000-000000000000
PROCESSOR
0 sec
1
split
0
53d39b93-9004-3cbf-0000-000000000000
1 GB
10000
f1321b94-3456-3b5d-0000-000000000000
PROCESSOR
0 sec
1
success
0
7f4f1c6c-5d45-329c-0000-000000000000
1 GB
10000
14.18456080125975
627.3152270141991
FUNNEL
0 sec
1
incompatible
0
163.06466424748442
742.6188856671531
3.9868304019100833
412.6253378924953
nifi-kite-nar
org.apache.nifi
1.4.0
WARN
1
Hadoop configuration files
Record schema
Record schema
kite-compression-type
ALL
false
30 sec
Record schema
"type": "record",
"name": "NifiHeartBeat_v3",
"fields": [{
"name": "MeasureId",
"type": "string",
"default": "null"
"name": "Value",
"type": "string",
"default": "null"
"name": "AuditDateTime",
"type": "string",
"default": "null"
"name": "DATA_SOURCE",
"type": "string",
"default": "null"
SNAPPY
0
0 sec
TIMER_DRIVEN
1 sec
ConvertJSONToAvro
false
failure
false
incompatible
false
success
RUNNING
org.apache.nifi.processors.kite.ConvertJSONToAvro
2.0773093815028005
204.60975040057042
nifi-standard-nar
org.apache.nifi
1.4.0
WARN
1
JsonPath Expression
JsonPath Expression
Null Value Representation
ALL
false
30 sec
JsonPath Expression
empty string
0
0 sec
TIMER_DRIVEN
1 sec
SplitJson
true
failure
true
original
false
split
RUNNING
org.apache.nifi.processors.standard.SplitJson
74ba9117-3cc5-38ad-0000-000000000000
0.0
0.0
nifi-standard-nar
org.apache.nifi
1.4.0
WARN
1
File Size
File Size
Batch Size
Batch Size
Data Format
Data Format
Unique FlowFiles
Unique FlowFiles
generate-ff-custom-text
character-set
character-set
report.url
report.url
ALL
false
30 sec
File Size
0B
Batch Size
1
Data Format
Text
Unique FlowFiles
false
"MeasureId": "nifiHeartBeat",
"Value": "1",
"AuditDateTime": "Tue Jan 16 13:48:58 CET 2018",
"DATA_SOURCE": "20083"
"Value": "1",
character-set
UTF-8
report.url
https://domain.com/report/foo.txt
0
1111111110 sec
TIMER_DRIVEN
1 sec
GenerateFlowFile
false
success
STOPPED
org.apache.nifi.processors.standard.GenerateFlowFile
01/16/2018 12:39:36 EST
