Accepted Solution
Using Rest API calls how would I call a lineage call with multiple entityids specified in the url
 I'm connecting to Navigator and attempting to make rest api calls.
I keep getting
  "message" : "Invalid id : 4500 5267"
when trying to make a lineage call with multiple entityids.
The url i'm using is below
http://vm-cloudera-59:7187/api/v10/lineage3/?entityIds=4500%205267
Topics: 3
Kudos: 109
Solutions: 67
Re: Using Rest API calls how would I call a lineage call with multiple entityids specified in the ur
Do either of those ids work with only one listed? That will rule out bad entity ids.
Based on one of the other calls you could try the below URL.
http://vm-cloudera-59:7187/api/v10/lineage3/?entityIds=4500&entityIds=5267
Thanks!. Looks like your suggested call successfully returned.
New solutions
