[FLaNK] Smart Weather Applications with Flink SQL and Smart Weather Websocket Application with Kafka Consumer
- Oct 5, 2026 8:54 AM UTC
- 0 replies
- 6135 views
- Translate All
Sometimes you want to acquire, route, transform, live query, and analyze all the weather data in the United States while those reports happen. With FLaNK, it's a trivial process to do.
From Kafka to Kudu for Any Schema of Any Type of Data - No Code, Two Steps
The Schema Registry has full Swagger-ized Runnable REST API Documentation. Integrate, DevOps, and Migration in a simple script.
You like drill-down maps, you got them:
Reference:
Ingesting all weather data with Apache
Source
Schemas
SQL
| INSERT INTO weathernj | |
| SELECT `location`, station_id,latitude,longitude,observation_time,weather, | |
| temperature_string, temp_f,temp_c,relative_humidity,wind_string,wind_dir,wind_degrees,wind_mph, | |
| wind_kt, pressure_in,dewpoint_string,dewpoint_f,dewpoint_c | |
| FROM weather | |
| WHERE | |
| `location` is not null and `location` <> 'null' and trim(`location`) <> '' and `location` like '%NJ'; |
Example Slack Output
http://forecast.weather.gov/images/wtf/small/ovc.png Location Cincinnati/Northern Kentucky International Airport, KY Station KCVG
Temperature: 49.0 F (9.4 C)
Humdity: 83
Wind East at 3.5 MPH (3 KT)
Overcast
Dewpoint 44.1 F (6.7 C)Observed at Tue, 27 Oct 2020 11:52:00 -0400---- tracking info ---- UUID: 2cb6bd67-148c-497d-badf-dfffb4906b89
Kafka offset: 0
Kafka Timestamp: 1603818351260
[FLaNK] Smart Weather Websocket Application - Kafka Consumer
This is based on Koji Kawamura's excellent GIST:
As part of my Smart Weather Application, I wanted to display weather information as it arrives on a webpage using web sockets. Koji has an excellent NiFi flow that does it. I tweaked it and add some things since I am not using Zeppelin. I am hosting my webpage with NiFi as well.
We simply supply a webpage that makes a WebSocket connection to NiFi and NiFi keeps a cache in HBase to know what the client is doing. This cache is updated by consuming from Kafka. We can then feed events as they happen to the page.
Here is the JavaScript for the web page interface to WebSockets:
| <script> | |
| function sendMessage(type, payload) { | |
| websocket.send(makeMessage(type, payload)); | |
| function makeMessage(type, payload) { | |
| return JSON.stringify({ | |
| 'type': type, | |
| 'payload': payload | |
| var wsUri = "ws://edge2ai-1.dim.local:9091/test"; | |
| websocket = new WebSocket(wsUri); | |
| websocket.onopen = function(evt) { | |
| sendMessage('publish', { | |
| "message": document.getElementById("kafkamessage") | |
| websocket.onerror = function(evt) {console.log('ERR', evt)}; | |
| websocket.onmessage = function(evt) { | |
| var dataPoints = JSON.parse(evt.data); | |
| var output = document.getElementById("results"); | |
| var dataBuffer = "<p>"; | |
| for(var i=0;i<dataPoints.length;i++) | |
| dataBuffer += " <img src=\"" + dataPoints[i].icon_url_base + dataPoints[i].icon_url_name + "\"> " + dataPoints[i].location + | |
| dataPoints[i].station_id + "@" + dataPoints[i].latitude + ":" + | |
| dataPoints[i].longitude + "@" + dataPoints[i].observation_time + | |
| dataPoints[i].temperature_string + "," + dataPoints[i].relative_humidity + "," + | |
| dataPoints[i].wind_string +"<br>"; | |
| output.innerHTML = output.innerHTML + dataBuffer + "</p><br>"; | |
| </script> Video Walkthrough: https://www.twitch.tv/videos/797412192?es_id=bbacb7cb39 Source Code: https://github.com/tspannhw/SmartWeather/tree/main Kafka Topic ![]() The schema registry has a live Swagger interface to it's REST API NiFi Flow Overview Ingest Via REST All US Weather Data from Zipped XML As Data Streamings In, We Can Govern It Ingested Data is Validated Against It's Schema Then Pushed to Kafka as Avro We consume that Kafka data in-store it in Kudu for analytics We host a web page for our Websockets Application in NiFi with 4 simple processors. Listen and Put Web Socket Messages Between NiFi Server and Web Application Kafka Data is Cached for Websocket Applications Set the Port for WebSockets via Jetty Web Server
![]() Use HBase As Our Cache
We can monitor our Flink SQL application from the Global Flink Dashboard
We can query our Weather data store in Apache Kudu via Apache Impala through Apache Hue Kudu Visualizations of Our Weather Data in Cloudera Visual Applications
