Skip to main content
rchaman
Silver ⭐️⭐️
April 19, 2019
Sensor Data Analysis using HDP and HDF - Part 2
  • October 5, 2026 at 9:01 AM
  • 0 replies
  • 1377 views
  • Translate All
NIFI Installation on HDP
We will go through step by step instructions how to setup your own data pipeline. First to save time and resources we will install NiFi on HDP cluster using mpack.
1. Install and setup the HDP cluster.
2. Install the HDF mpack (versions may vary) on ambari server node and restart the ambari server.
1. wget http://public-repo-1.hortonworks.com/HDF/centos7/3.x/updates/3.2.0.0/tars/hdf_ambari_mp/hdf-ambari-mpack-3.2.0.0-520.tar.gz
2. cp -r /var/lib/ambari-server/resources /var/lib/ambari-server/resources.backup
3. ambari-server install-mpack --mpack=hdf-ambari-mpack-3.2.0.0-520.tar.gz  --verbose
4. ambari-server restart
3. Once we restart the ambari-server, we will be now able to add Nifi service to the same HDP cluster. Two different clusters can be used for HDP and HDF, however we are using only one to reduce the complexity.
4. Select NiFi service
5. Resume the installation after typing in the Master key, encryption and Nifi CA token password
6. Once it is done, validate the Nifi installation by opening the WebUI.
Part 1, Part 2, Part 3, Part 4, Part 5
